Discuss
How to remove range top
 in
I think I need to replace one of my igniter switches. How do I remove the range top of this
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How to remove range top
  #1 (permalink)
Old 11-12-2013, 09:09 AM
Junior Member
Olegruf is on a distinguished road
Default How to remove range top
Model Number: 79046819991   Brand: Kenmore   Age: More than 10 years
I think I need to replace one of my igniter switches. How do I remove the range top of this Kenmore Elite drop in gas/electric range?
Related Models
Kenmore 79046819992 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046819993 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046822100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046822101 SLIDE-IN RANGE
Kenmore 79046822102 SEARS/ELECTRIC RANGE
Kenmore 79046823100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046823101 SEARS/ELECTRIC RANGE
Kenmore 79046823102 SEARS/ELECTRIC RANGE
Kenmore 79046824100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046824101 SLIDE-IN RANGE
Kenmore 79046824102 SEARS/ELECTRIC RANGE
Kenmore 79046829100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046829101 SLIDE-IN RANGE
Kenmore 79046829102 SEARS/ELECTRIC RANGE
Kenmore 79046832100 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046832101 SEARS/GAS RANGE
Kenmore 79046832102 SEARS/GAS RANGE
Kenmore 79046833100 DUAL FUEL RANGE
Kenmore 79046833101 SEARS/GAS RANGE
Kenmore 79046833102 SEARS/GAS RANGE
Kenmore 79046834100 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046834101 SEARS/GAS RANGE
Kenmore 79046834102 SEARS/GAS RANGE
Kenmore 79046839100 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046839101 SEARS/GAS RANGE
Kenmore 79046839102 SEARS/GAS RANGE
Kenmore 79046892900 ELECTRIC RANGE
Kenmore 79046892901 ELECTRIC RANGE
Kenmore 79046892902 ELECTRIC RANGE
Kenmore 79046892903 ELECTRIC RANGE
Kenmore 79046893900 ELECTRIC RANGE
Kenmore 79046893901 ELECTRIC RANGE
Kenmore 79046893902 ELECTRIC RANGE
Kenmore 79046893903 ELECTRIC RANGE
Kenmore 79046899900 ELECTRIC RANGE
Kenmore 79046899901 ELECTRIC RANGE
Kenmore 79046899902 ELECTRIC RANGE
Kenmore 79046899903 ELECTRIC RANGE
Kenmore 79046991100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046991102 SEARS/ELECTRIC RANGE
Kenmore 79046991103 SEARS/ELECTRIC RANGE
Kenmore 79046992100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046992102 SEARS/ELECTRIC RANGE
Kenmore 79046992103 SEARS/ELECTRIC RANGE
Kenmore 79046994100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046994102 SEARS/ELECTRIC RANGE
Kenmore 79046994103 SEARS/ELECTRIC RANGE
Kenmore 79046999100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046999102 SEARS/ELECTRIC RANGE
Kenmore 79046999103 SEARS/ELECTRIC RANGE
Kenmore 79047102400 GAS RANGE
Kenmore 79047104400 GAS RANGE
Kenmore 79047109400 GAS RANGE
Kenmore 79047152400 GAS RANGE
Kenmore 79047153400 GAS RANGE
Kenmore 79047153401 GAS RANGE
Kenmore 79047153402 GAS RANGE
Kenmore 79047153403 GAS RANGE
Kenmore 79047154400 GAS RANGE
Kenmore 79047159400 GAS RANGE
Kenmore 79047172400 ELECTRIC OVEN
Kenmore 79047172401 ELECTRIC OVEN
Kenmore 79047179400 ELECTRIC OVEN
Kenmore 79047179401 ELECTRIC OVEN
Kenmore 79047732400 ELECTRIC OVEN
Kenmore 79047732401 ELECTRIC OVEN
Kenmore 79047732402 ELECTRIC OVEN
Kenmore 79047732404 ELECTRIC OVEN
Kenmore 79047732405 ELECTRIC OVEN
Kenmore 79047732406 ELECTRIC OVEN
Kenmore 79047732407 ELECTRIC OVEN
Kenmore 79047733400 ELECTRIC OVEN
Kenmore 79047733401 ELECTRIC OVEN
Kenmore 79047733402 ELECTRIC OVEN
Kenmore 79047733404 ELECTRIC OVEN
Kenmore 79047733405 ELECTRIC OVEN
Kenmore 79047733406 ELECTRIC OVEN
Kenmore 79047733407 ELECTRIC OVEN
Kenmore 79047733408 ELECTRIC OVEN
Kenmore 79047734400 ELECTRIC OVEN
Kenmore 79047734401 ELECTRIC OVEN
Kenmore 79047734402 ELECTRIC OVEN
Kenmore 79047734404 ELECTRIC OVEN
Kenmore 79047739400 ELECTRIC OVEN
Kenmore 79047739401 ELECTRIC OVEN
Kenmore 79047739402 ELECTRIC OVEN
Kenmore 79047739404 ELECTRIC OVEN
Kenmore 79047739405 ELECTRIC OVEN
Kenmore 79047739406 ELECTRIC OVEN
Kenmore 79047739407 ELECTRIC OVEN
Kenmore 79047762400 ELECTRIC OVEN
Kenmore 79047762401 ELECTRIC OVEN
Kenmore 79047762402 ELECTRIC OVEN
Kenmore 79047762404 ELECTRIC OVEN
Kenmore 79047762405 ELECTRIC OVEN
Kenmore 79047762406 ELECTRIC OVEN
Kenmore 79047763400 ELECTRIC OVEN
Kenmore 79047763401 ELECTRIC OVEN
Kenmore 79047763402 ELECTRIC OVEN
Kenmore 79047763404 ELECTRIC OVEN
Kenmore 79047763405 ELECTRIC OVEN
Kenmore 79047763406 ELECTRIC OVEN
Kenmore 79047763407 ELECTRIC OVEN
Kenmore 79047764400 ELECTRIC OVEN
Kenmore 79047764401 ELECTRIC OVEN
Kenmore 79047764402 ELECTRIC OVEN
Kenmore 79047764404 ELECTRIC OVEN
Kenmore 79047764405 ELECTRIC OVEN
Kenmore 79047764406 ELECTRIC OVEN
Kenmore 79047769400 ELECTRIC OVEN
Kenmore 79047769401 ELECTRIC OVEN
Kenmore 79047769402 ELECTRIC OVEN
Kenmore 79047769404 ELECTRIC OVEN
Kenmore 79047769405 ELECTRIC OVEN
Kenmore 79047769406 ELECTRIC OVEN
Kenmore 79047772400 ELECTRIC OVEN
Kenmore 79047772401 ELECTRIC OVEN
Kenmore 79047772403 ELECTRIC OVEN
Kenmore 79047772404 ELECTRIC OVEN
Kenmore 79047772405 ELECTRIC OVEN
  #2 (permalink)
Old 11-12-2013, 10:26 AM
Senior Member
Appliance Ninja is on a distinguished road
Default
That top will require that you first remove the burner grates and drip pans. Once the burners are removed, you will see two screws under the burners, remove those and the pans will come out. Then,. I believe there are tension clips under the front edge of the top that, when released, will allow the top to hinge up. The pans you need to remove are pictured at the link below.
Frigidaire 318168124 Pan-Burner Large Bl - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How do you remove top of range Palmj74 Oven Repair (including Ranges and Cooktops) 0 03-27-2012 12:46 PM
How do I remove/open maintop of range MLO Oven Repair (including Ranges and Cooktops) 1 02-17-2012 04:04 PM
how to remove glass range top pat nelon Oven Repair (including Ranges and Cooktops) 0 05-08-2011 07:18 AM
How to remove ignitor from range top? dieselgg Oven Repair (including Ranges and Cooktops) 0 11-13-2010 06:35 PM
How to remove range element from top dieselgg Oven Repair (including Ranges and Cooktops) 1 06-30-2009 05:14 PM
