I have been dealing with a hot surface light on for one of my burners that does not work. I have taken the burner out and have seen that the glass tube that covers the limiter is cracked and slightly broken. Will that cause the problem and if so, is there a way to repair that or do I have to buy a new burner. ITs the bridge burner so its not an expense I want to make. This is the second time I have replaced this burner already.
