I've got a double oven (HBL765 A UC/01) and the top oven will not turn off. Seems like the oven runs fine when I set the temp, and mode, etc... but when I try to turn it off it appears to be off yeT continues to heat and the fan continues to run. I flipped the circuit breaker for an hour and when turned it back on the oven started to heat again on it's own and the fan turned back on. Help?!?! Is it the control board? Any idea which part # and a good place to buy it from? I'm pretty handy so I think I can do it myself if it's not too complicated and there are no specialized tools. Thank you for the input.
