The local Gas & Electric Co was in the area today updating the electric meters. Tonight, my oven will no longer heat. It worked last night, but not tonight. Anyway, the stovetop works and the broil option works.
Any ideas?
thanks in advance
Check the bake ignitor at the bottom if it's white or greyish or ashy color replace it. Check the voltage at that ignitor when you hit the bake function you should have 120v if you do just replace the ignitor and if you don't have 120v after pressing the bake function more then likely the main control is going out or you have a short in the wire going from the main control do a continuity test on the wire to the main board if that checks out ok replace the main board and overlay piece. Parts for GE PGB928SEM1SS Range - AppliancePartsPros.com
That worked! Thanks for the help. The igniter had some white on it and looked like a small crack too. I swapped it in about 10 total minutes and am back in business.
Thanks again!
You're very welcome and i'm glad it helped
