Discuss
Kenmore Elite Double Oven Not Keeping Temperature
 in
My wife and I bought a Kenmore 790-48193000 30” ElectricDouble-Oven (Frigidaire). We have recently noticed the upper oven not holdingits
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Elite Double Oven Not Keeping Temperature
  #1 (permalink)
Old 11-05-2013, 04:44 AM
Junior Member
rrchacon is on a distinguished road
Default Kenmore Elite Double Oven Not Keeping Temperature
Model Number: 790.48193000   Brand: Kenmore   Age: 1 - 5 years
My wife and I bought a Kenmore 790-48193000 30” ElectricDouble-Oven (Frigidaire). We have recently noticed the upper oven not holdingits temperature accurately, sometimes falling below its indicated setting by up to 150-degrees F. For instance, if we set “Cakes Breads” option at350-degrees F for the UPPER oven, the indicator eventually shows 350-degrees. When we measure the oven temperature, it shows about 396-degrees. Once we place the cake or cookies inside the oven, we see the indicator cycling the upper/lower elements to apparently keep the oven at the chosen setting (350). However, when we measure the oven’s interior, it is about 184-degrees. Once we turn it off, and immediately restart it, it will reach about 390 through 398 and then go through the same gradual ‘cool-off’ period even though the control panel shows the chosen temperature. Bottom oven is NOT affected.
I just replaced the temperature sensors to no avail. The upper oven continues the same behavior while the bottom oven is operating flawlessly.
Could you suggest where to find a Repair/Service manual or a wiring diagram forsale for these ovens or is there any other suggestions I could try?
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
  #2 (permalink)
Old 11-05-2013, 06:03 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
There's a relay board behind the control that has problems alot of times on these units or it's your main control ecu....what happens is the heat or the moisture from cooking gets up into the electronics and makes a bugger out of them. Also avoid using the self cleaning mode if you have one this will cause problems as well........both these parts are around $400. and i'm sorry i couldn't tell you off hand how to determine the problem unless you can hear the relays malfunctioning. The schematics don't show up on this site but you can go to s e a r s website and read the schematics.
  #3 (permalink)
Old 08-09-2014, 06:07 PM
Junior Member
Victoria Cooks is on a distinguished road
Default
Quote:
We have the same oven and same problem. Sears repair came out 8 times and replaced board and recalibrated 8 times. Wouldn't honor lemon agreement until we got very insistent. They just let us know that we have a $900 credit to buy a new $2500 oven to replace the one that hasn't worked properly since the first time we used the automatic oven cleaner. Sears and their protection service agreements have been a terrible experience.
  #4 (permalink)
Old 11-06-2016, 12:31 PM
Junior Member
shyhootska is on a distinguished road
Default both ovens stop heating at random
We have experienced the same issues. The top and bottom ovens both will stop heating at random while both are on or individually. The temp probe sensors in both top and bottom ovens test out at 1780 and 1870 ohms so I am ruling them out. I am going to replace the oven control board and see if this solves it. I had a sears "rep" at my house while it was under warranty more than once to address the issue and they could not replicate the problem. He said he wasn't going to replace any parts if he couldn't find the problem. I think he knew what would fix it but didn't want to come back with the correct part. We bought all new Kenmore Elite appliances and have had problems with EVERY SINGLE ONE OF THEM! To say I'm extremely disappointed with Sears appliances is an understatement! The Elite product line used the same components as the low end Kenmore line. GARBAGE!
  #5 (permalink)
Old 11-06-2016, 05:32 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
What's really wrong with most new ranges/ovens is they don't use heavy enough relays. So 2 o 3 years down the road the relay's contacts are fried and it either becomes intermittent or quits altogether.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Problem with oven keeping temperature jmbauer Oven Repair (including Ranges and Cooktops) 3 08-17-2012 02:17 AM
Oven not keeping heating temperature Caroline Sanfilippo Oven Repair (including Ranges and Cooktops) 0 12-14-2011 01:13 PM
GE Profile Refrig not keeping temperature trapshotr15 Refrigerator & Freezer Repair 0 11-16-2011 05:22 PM
Refrigerator is not keeping correct temperature Leon Barzey Refrigerator & Freezer Repair 1 09-09-2009 04:36 AM
Oven not keeping correct Temperature Andrew Mail Oven Repair (including Ranges and Cooktops) 1 11-27-2007 03:34 PM
