Discuss
No ignitor spark on Dacor gas cooktop
 in
I don't have a spark on one of the ignitors. When I clean it with alcohol, it sparks fine but
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No ignitor spark on Dacor gas cooktop
  #1 (permalink)
Old 11-04-2013, 01:14 PM
Junior Member
Saltman41 is on a distinguished road
Default No ignitor spark on Dacor gas cooktop
Model Number: SGM365   Brand: Dacor   Age: More than 10 years
I don't have a spark on one of the ignitors. When I clean it with alcohol, it sparks fine but that only lasts for a few minutes. Then, no spark. I would like to know how to replace the burner ignitor. Any help would be appreciated.
Steve
Related Models
 SGM365 COOKTOP
Thermador SGN30B GAS COOKTOP
Thermador SGN30S GAS COOKTOP
Thermador SGN30W GAS COOKTOP
Thermador SGN36GB GAS COOKTOP
Thermador SGN36GS GAS COOKTOP
Thermador SGN36GW GAS COOKTOP
Thermador SGNCV36GB GAS COOKTOP
Thermador SGNCV36GS GAS COOKTOP
Thermador SGNCV36GW GAS COOKTOP
Roper SGP335XW0 Range (gas)*
Roper SGP335XW1 Range (gas)*
Roper SGP335XX2 Range (gas)*
White Westinghouse SGQ2152HS0 DRYER
White Westinghouse SGQ2152HS1 DRYER
White Westinghouse SGQ2170KS0 DRYER
 SGQ7000FS0 ELECTROLUX/DRYER
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR231HQ0 DRYER
White Westinghouse SGR231HQ1 DRYER
White Westinghouse SGR231HS0 DRYER
White Westinghouse SGR231HS1 DRYER
White Westinghouse SGR341AQ0 Dryer - W.west
White Westinghouse SGR341AQ1 Dryer - West/grupo Gomo
White Westinghouse SGR341AQ2 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ3 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ4 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ5 White Westinghouse/dryer
White Westinghouse SGR341AS0 Dryer - W.west
White Westinghouse SGR341AS1 Dryer - West/grupo Gomo
White Westinghouse SGR341AS2 White Westinghouse/gas Dryer
White Westinghouse SGR341AS3 White Westinghouse/gas Dryer
White Westinghouse SGR341AS4 White Westinghouse/gas Dryer
White Westinghouse SGR341AS5 White Westinghouse/dryer
White Westinghouse SGR341CC0 White Westinghouse/dryer
White Westinghouse SGR341FC0 White Westinghouse/dryer
White Westinghouse SGR351CQ0 White Westinghouse/dryer
White Westinghouse SGR351CS0 White Westinghouse/dryer
White Westinghouse SGR351FQ0 White Westinghouse/dryer
White Westinghouse SGR351FS0 White Westinghouse/dryer
White Westinghouse SGR351HQ0 DRYER
White Westinghouse SGR351HQ1 DRYER
White Westinghouse SGR351HS0 DRYER
White Westinghouse SGR351HS1 DRYER
White Westinghouse SGR641HQ0 DRYER
White Westinghouse SGR641HQ1 DRYER
White Westinghouse SGR641HS0 DRYER
White Westinghouse SGR641HS1 DRYER
Thermador SGS/X304ZB
Thermador SGS/X304ZS
Thermador SGS/X304ZW
Thermador SGS/X365ZB
Thermador SGS/X365ZS
Thermador SGS/X365ZW
Thermador SGS304ZB
Thermador SGS304ZS
Thermador SGS304ZW
Thermador SGS30B GAS COOKTOP
Thermador SGS30S GAS COOKTOP
Thermador SGS30W GAS COOKTOP
Thermador SGS365ZB
Thermador SGS365ZS
Thermador SGS365ZW
Thermador SGS36GB GAS COOKTOP
Thermador SGS36GS GAS COOKTOP
Thermador SGS36GW GAS COOKTOP
Whirlpool SGS375HQ0 30" GAS FREESTANDING, SELF-CLEAN RANGE
Whirlpool SGS375HQ5 GAS RANGE
Whirlpool SGS375HQ6 GAS RANGE
Whirlpool SGS375HQ7 COOKING PRODUCT - GAS
Roper SGS395XX0 Range (gas)*
Whirlpool SGS395XX1
Whirlpool SGS395XX2
Thermador SGS456ZS
Thermador SGSCV36GB GAS COOKTOP
Thermador SGSCV36GS GAS COOKTOP
Thermador SGSCV36GW GAS COOKTOP
Thermador SGSX304ZB
Thermador SGSX304ZS
Thermador SGSX304ZW
Thermador SGSX365ZB
Thermador SGSX365ZS
Thermador SGSX365ZW
Thermador SGSX456ZB
Thermador SGSX456ZS
Thermador SGSX456ZW
Thermador SGT3001 COOKTOP
Thermador SGT3002 COOKTOP
Thermador SGT36 COOKTOP
Thermador SGT3601 COOKTOP
Thermador SGT36G01 COOKTOP
Thermador SGT36G02 COOKTOP
Frigidaire SGWS1349AS0 Frigidaire/washer
Bosch SGZ1000
Bosch SGZ1005
Bosch SGZ1024
Bosch SGZ1025
Bosch SGZ1040
Bosch SGZ1042
Bosch SGZ1046
Bosch SGZ2004
Thermador SH01BG
Frigidaire SH205C1QA Kel(v0) / Room Air Conditioner
Frigidaire SH205C1QB Kel(v1) / Room Air Conditioner
Frigidaire SH206C1QA Kel(v0) / Room Air Conditioner
Frigidaire SH206D1QA Kel(v1) / Room Air Conditioner
General Electric SH208W0WW Washer
Frigidaire SH310C1QA Kel(v0) / Room Air Conditioner
Frigidaire SH310D1QA Kel(v1) / Air Conditioner
Hardwick SH4-34A9 SURFACE UNIT- GAS
Hardwick SH4-34W9 SURFACE UNIT- GAS
Frigidaire SH418C2SA Kel(v0) / Room Air Conditioner
Frigidaire SH418D2SA Kel(v1) / Room Air Conditioner
Hardwick SH7241819R WALLOVEN- STD GAS
Whirlpool SHF3801W0 Dishwasher
Whirlpool SHF3804W2 Dishwasher
Whirlpool SHF4500W0 Dishwasher
Whirlpool SHF5500W0 Dishwasher
Whirlpool SHF5501W0 Dishwasher
  #2 (permalink)
Old 11-04-2013, 05:52 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Get to the spark module and switch ignitor wires around (do not switch the main power wires coming into the spark module which are usually red & white or black and white should be 120v) Take the one that's not working and plug it into another spot in that block it doesn't matter which one you swap it with all ignitors should come on no matter what knob you turn on. If the burner works fine after the swap replace the spark module and if not check your ignitor wires/ignitor or burn switch harness. Do no try to do a voltage check to the ignitor from the spark module the voltage is too high and will burn up your meter. Ohm out the wires from the spark module to the ignitors also to make sure they aren't shorting out.
Cabinet Parts parts for Dacor SGM365 - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spark Harness & Spark Module for Cooktop? DFilice Oven Repair (including Ranges and Cooktops) 1 03-18-2013 07:26 PM
Dacor Spark Module psgreenroom Oven Repair (including Ranges and Cooktops) 0 09-19-2012 02:19 PM
No spark on Dacor SGM365 Cooktop ken speicher Oven Repair (including Ranges and Cooktops) 0 04-11-2012 09:55 AM
Cooktop Spark Ignitor drummer Oven Repair (including Ranges and Cooktops) 0 07-22-2010 04:10 PM
Cooktop Spark Ignitor Acting Squirrel halapeno Oven Repair (including Ranges and Cooktops) 0 03-31-2008 11:33 AM
