Discuss
GE JDP36 temperature set issue
 in
I'm having an issue with my GE JDP36 oven. When I try to set the baking temperature or broil, it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE JDP36 temperature set issue
  #1 (permalink)
Old 11-03-2013, 07:57 AM
Junior Member
jillybean68 is on a distinguished road
Default GE JDP36 temperature set issue
Brand: GE   Age: More than 10 years
When I try to set the baking temperature or broil, it will appear to start preheating (ex: I enter 350 degrees, the display panel will read 100 degrees as though it is preheating), then w/in about 30 seconds, it shuts off. Power is still on, but the temperature set cuts off and the oven does not preheat.
I'm thinking it has to be in the control panel, and I have the front panel pulled apart. But this is a costly part, so I'd like some advise before trying this. Also, if this is it, I would like to know how complicated this is to replace as it appears all the wires from the new control panel will need to be rewired.
Any help is appreciated.
Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Temperature Issue diybruce Oven Repair (including Ranges and Cooktops) 7 06-08-2012 05:40 PM
Temperature sensor issue Stan Stevens Oven Repair (including Ranges and Cooktops) 3 06-15-2011 09:44 AM
GE Refrigerator Temperature control issue mcistaro Refrigerator & Freezer Repair 1 12-10-2010 03:31 AM
GE Refrigerator Temperature control issue mcistaro Refrigerator & Freezer Repair 0 12-04-2010 05:52 PM
Oven Temperature issue jojo12 Oven Repair (including Ranges and Cooktops) 1 05-16-2008 01:24 PM
