Hi, I need help figuring out what I think is a strange issue with my range. The left front burner came on all by its self and I could not shut it off. The switch was in off position and I ended up shutting power off to the whole range at the service panel. I've never experienced anything like that before. I would assume it is a switch problem but not sure. I was cooking on other burners and using oven when this took place. At first I thought I bumped the knob by accident, but I didn't. Has anyone else had this happen? Any advise would be appreciated. Thanks, stevet:cool:
