Discuss
Kenmore gas range bottom burner not working
 in
The bottom burner on this oven does not work. The range and the broiler work fine. When you select bake,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore gas range bottom burner not working
  #1 (permalink)
Old 10-29-2013, 10:09 AM
Junior Member
scott mcgourley is on a distinguished road
Default Kenmore gas range bottom burner not working
Model Number: 362.75492000   Brand: Kenmore   Age: More than 10 years
The bottom burner on this oven does not work. The range and the broiler work fine. When you select bake, the element glows orange but the gas never comes on. If you tap on the gas control valve, it will come on, but will go off in 36 seconds and is very repeatable. I checked the orifice and it is fine, I also replaced the control valve (WB19K36) and the symptoms remain the same. It appears that the temp control and brain are working properly as if I heat up the oven with the broiler, then switch to bake, the oven will show that it is preheated to the correct temperature. It seems as if I have two bad valves, but I tend to think that is not logical. I have checked all connections and they are solid. What do I test from here?
Related Models
Magic Chef 3621WPA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621WPW RANGE- F/S CONT CLEAN ELE
Magic Chef 3621WRA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621WRW RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XPA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XPW RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XRA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XRW RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XPA RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XPW RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XRA RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XRW RANGE- F/S CONT CLEAN ELE
Amana 36261 REF - SXS/I&W
Kenmore 3626101190 GAS RANGE
Kenmore 3626101191 GAS RANGE
Kenmore 3626101192 GAS RANGE
Kenmore 3626101194 GAS RANGE
Kenmore 3626101195 GAS RANGE
Kenmore 3626101196 GAS RANGE
Kenmore 3626101197 GAS RANGE
Kenmore 3626101890 GAS RANGE
Kenmore 3626101891 GAS RANGE
Kenmore 3626101892 GAS RANGE
Kenmore 3626101894 GAS RANGE
Kenmore 3626101895 GAS RANGE
Kenmore 3626101896 GAS RANGE
Kenmore 3626101897 GAS RANGE
Kenmore 36261020101 GAS RANGE
Kenmore 36261020102 GAS RANGE
Kenmore 36261020103 GAS RANGE
Kenmore 36261021890 GAS RANGE
Kenmore 36261021891 GAS RANGE
Kenmore 36261021892 GAS RANGE
Kenmore 36261021893 GAS RANGE
Kenmore 36261021894 GAS RANGE
Kenmore 36261028890 GAS RANGE
Kenmore 36261028891 GAS RANGE
Kenmore 36261028892 GAS RANGE
Kenmore 36261028893 GAS RANGE
Kenmore 36261028894 GAS RANGE
Kenmore 36261061690 GAS RANGE
Kenmore 36261101000 ELECTRIC RANGE
Kenmore 36261101001 ELECTRIC RANGE
Kenmore 36261108000 ELECTRIC RANGE
Kenmore 36261108001 ELECTRIC RANGE
Kenmore 36261111699 KENMORE GAS RANGE
Kenmore 3626111190 GAS RANGE
Kenmore 3626111191 GAS RANGE
Kenmore 3626111192 GAS RANGE
Kenmore 3626111193 GAS RANGE
Kenmore 3626111194 GAS RANGE
Kenmore 3626111195 GAS RANGE
Kenmore 3626111196 GAS RANGE
Kenmore 3626111197 GAS RANGE
Kenmore 3626111198 GAS RANGE
Kenmore 36261118699 KENMORE GAS RANGE
Kenmore 3626111890 GAS RANGE
Kenmore 3626111891 Free Standing, Gas
Kenmore 3626111892 GAS RANGE
Kenmore 3626111893 Range (gas)*
Kenmore 3626111894 Range (gas)*
Kenmore 3626111895 GAS RANGE
Kenmore 3626111896 GAS RANGE
Kenmore 3626111897 GAS RANGE
Kenmore 3626111898 GAS RANGE
Kenmore 36261120101 GAS RANGE
Kenmore 36261120102 GAS RANGE
Kenmore 36261120103 GAS RANGE
Kenmore 36261120104 GAS RANGE
Kenmore 36261121890 GAS RANGE
Kenmore 36261121891 GAS RANGE
Kenmore 36261121892 GAS RANGE
Kenmore 36261121893 GAS RANGE
Kenmore 36261121894 GAS RANGE
Kenmore 36261121895 GAS RANGE
Kenmore 36261121896 GAS RANGE
Kenmore 36261128890 GAS RANGE
Kenmore 36261128891 GAS RANGE
Kenmore 36261128892 GAS RANGE
Kenmore 36261128893 GAS RANGE
Kenmore 36261128894 GAS RANGE
Kenmore 36261128895 GAS RANGE
Kenmore 3626121190 GAS RANGE
Kenmore 3626121191 Free Standing, Gas
Kenmore 3626121192 GAS RANGE
Kenmore 3626121193 GAS RANGE
Kenmore 3626121194 GAS RANGE
Kenmore 3626121890 GAS RANGE
Kenmore 3626121891 GAS RANGE
Kenmore 3626121892 GAS RANGE
Kenmore 3626121893 GAS RANGE
Kenmore 3626121894 GAS RANGE
Kenmore 3626125190 KENMORE GAS RANGE
Kenmore 3626125191 GAS RANGE
Kenmore 3626125192 GAS RANGE
Kenmore 3626125193 GAS RANGE
Kenmore 3626125890 GAS RANGE
Kenmore 3626125891 GAS RANGE
Kenmore 3626125892 GAS RANGE
Kenmore 3626125893 GAS RANGE
Kenmore 36261741000 ELECTRIC RANGE
Kenmore 36261741001 ELECTRIC RANGE
Kenmore 36261742000 ELECTRIC RANGE
Kenmore 36261742001 ELECTRIC RANGE
Kenmore 36261748000 ELECTRIC RANGE
Kenmore 36261748001 ELECTRIC RANGE
Kenmore 36262020300 GAS RANGE
Kenmore 36262020301 GAS RANGE
Kenmore 36262021300 GAS RANGE
Kenmore 36262021301 GAS RANGE
Kenmore 36262492000 ELECTRIC RANGE
Kenmore 36262492001 ELECTRIC RANGE
Kenmore 36262780100 ELECTRIC RANGE
Kenmore 36262780101 ELECTRIC RANGE
Kenmore 36262780102 ELECTRIC RANGE
Kenmore 36262780103 ELECTRIC RANGE
Kenmore 36262781000 ELECTRIC RANGE
  #2 (permalink)
Old 10-29-2013, 07:08 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Amp clamp test the ignitor.......it needs to be pulling 3 amps or more otherwise the safety valve won't release gas. If the ignitor is ashy or white it's going bad. Here's a page of video's that should help
gas oven wont light - YouTube.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Glass Top Range Left Front Burner not working J Boyer Oven Repair (including Ranges and Cooktops) 1 04-20-2012 04:56 PM
Kenmore Oven Bottom Burner Will Not Light kfost Oven Repair (including Ranges and Cooktops) 3 03-08-2011 06:24 AM
Kenmore Oven Bottom Burner Will Not Light kfost Oven Repair (including Ranges and Cooktops) 0 03-06-2011 12:19 PM
Gas oven bottom burner not working on gas stove lucas8026@comcast.net Oven Repair (including Ranges and Cooktops) 1 12-30-2010 07:34 AM
Maytag Double oven burner not working on bottom mirekjanowiak Oven Repair (including Ranges and Cooktops) 5 12-26-2009 03:38 PM
