Oven display does not appear. Can't see any indications or light in the display so trouble shooting mode can't be entered. Range top control lights, spark ignitors and all range gas functions work. Main control circuit board indicates approx 12 volts at 24 volt test point and approximately 0 volts at 12 volt test point. All connectors look seated and there are no signs of corrosion on either the main circuit board or the relay control circuit board. This range was purchased from a Sears Discount Outlet, and it may never been used or at most very little used.
