Each time I turn the oven on I smell a little gas. But my real consider is that it will not heat up. when I select bake default temp is 300 then drops to 250 etc It turns on but the fire doesn't increase. Can anyone help me with this problem?? Thank you so much. everything else works just fine and broil works too and all the controls work and light up except this problem with oven will not get hotter than 200 degrees.
