Discuss
Oven Temp is 336 to 390 when set for 350
 in
I just replaced the oven sensor. I am using a lab grade Fluke thermometer to measure internal temp. Comparing the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Temp is 336 to 390 when set for 350
  #1 (permalink)
Old 10-23-2013, 10:13 AM
Junior Member
richard506 is on a distinguished road
Default Oven Temp is 336 to 390 when set for 350
Model Number: MGR 7662   Brand: Maytag   Age: 1 - 5 years
I just replaced the oven sensor. I am using a lab grade Fluke thermometer to measure internal temp. Comparing the actual temp to oven sensor temp (pressing Cancel>Cancel>Start then + twice) shows that the oven sensor lags actual temp by about 10 to 20 degrees. I guess that's OK
So I set the oven for 350.
It will then go up to 396 before it shuts off. Then it coasts down to 336 before it reignites.
Setting the temperature adjustment override simply moves the 60 degree range up or down.
Is there any way to narrow this range in the LCC 190 Oven Control???
Having plus or minus 10 degrees would be nice.
Related Models
Maytag MGR1100ADW RANGE- F/S STD GAS
Maytag MGR1320ADA RANGE- F/S STD GAS
Maytag MGR1320ADW RANGE- F/S STD GAS
Maytag MGR1320BDW RANGE- F/S STD GAS
Maytag MGR2320ADA RANGE-F/S CONT CLEAN GAS
Maytag MGR2320ADW RANGE-F/S CONT CLEAN GAS
Maytag MGR4220ADW RANGE- S/C F/S GAS
Maytag MGR4410ADH RANGE- F/S STD GAS
Maytag MGR4410ADL RANGE- F/S STD GAS
Maytag MGR4410ADW RANGE- F/S STD GAS
Maytag MGR4410BDA RANGE- F/S STD GAS
Maytag MGR4410BDQ RANGE- F/S STD GAS
Maytag MGR4410BDW RANGE- F/S STD GAS
Maytag MGR4411BDQ RANGE- F/S STD GAS
Maytag MGR4411BDW RANGE- F/S STD GAS
Maytag MGR4450ADH RANGE- F/S STD GAS
Maytag MGR4450ADL RANGE- F/S STD GAS
Maytag MGR4450ADW RANGE- F/S STD GAS
Maytag MGR4450BDA RANGE- F/S STD GAS
Maytag MGR4450BDQ RANGE- F/S STD GAS
Maytag MGR4450BDW RANGE- F/S STD GAS
Maytag MGR4451ADB RANGE- F/S STD GAS
Maytag MGR4451ADQ RANGE- F/S STD GAS
Maytag MGR4451ADS RANGE- F/S STD GAS
Maytag MGR4451ADW RANGE- F/S STD GAS
Maytag MGR4451BDB RANGE- F/S STD GAS
Maytag MGR4451BDQ RANGE- F/S STD GAS
Maytag MGR4451BDS RANGE- F/S STD GAS
Maytag MGR4451BDW RANGE- F/S STD GAS
Maytag MGR4452ADB RANGE- F/S STD GAS
Maytag MGR4452ADQ RANGE- F/S STD GAS
Maytag MGR4452ADS RANGE- F/S STD GAS
Maytag MGR4452ADW RANGE- F/S STD GAS
Maytag MGR4452BDB RANGE- S/C F/S GAS
Maytag MGR4452BDQ RANGE- S/C F/S GAS
Maytag MGR4452BDS RANGE- S/C F/S GAS
Maytag MGR4452BDW RANGE- S/C F/S GAS
Maytag MGR4770ADH RANGE- F/S STD GAS
Maytag MGR4770ADL RANGE- F/S STD GAS
Maytag MGR4770ADW RANGE- F/S STD GAS
Maytag MGR5510ADH RANGE- S/C F/S GAS
Maytag MGR5510ADL RANGE- S/C F/S GAS
Maytag MGR5510ADW RANGE- S/C F/S GAS
Maytag MGR5605WB0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC I
Maytag MGR5605WW0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC I
Maytag MGR5710ADQ RANGE- S/C F/S GAS
Maytag MGR5710ADW RANGE- S/C F/S GAS
Maytag MGR5720ADH RANGE- S/C F/S GAS
Maytag MGR5720ADL RANGE- S/C F/S GAS
Maytag MGR5720ADT RANGE- S/C F/S GAS
Maytag MGR5720ADW RANGE- S/C F/S GAS
Maytag MGR5720BDQ RANGE- S/C F/S GAS
Maytag MGR5720BDW RANGE- S/C F/S GAS
Maytag MGR5721BDQ RANGE- S/C F/S GAS
Maytag MGR5721BDW RANGE- S/C F/S GAS
Maytag MGR5729ADA RANGE- S/C F/S GAS
Maytag MGR5729ADH RANGE- S/C F/S GAS
Maytag MGR5729ADL RANGE- S/C F/S GAS
Maytag MGR5729ADQ RANGE- S/C F/S GAS
Maytag MGR5729ADT RANGE- S/C F/S GAS
Maytag MGR5729ADW RANGE- S/C F/S GAS
Maytag MGR5730ADA RANGE- S/C F/S GAS
Maytag MGR5730ADH RANGE- S/C F/S GAS
Maytag MGR5730ADQ RANGE- S/C F/S GAS
Maytag MGR5730ADW RANGE- S/C F/S GAS
Maytag MGR5730BDB RANGE- S/C F/S GAS
Maytag MGR5730BDQ RANGE- S/C F/S GAS
Maytag MGR5730BDW RANGE- S/C F/S GAS
Maytag MGR5745ADA RANGE- S/C F/S GAS
Maytag MGR5745ADB RANGE- S/C F/S GAS
Maytag MGR5745ADW RANGE- S/C F/S GAS
Maytag MGR5750ADA RANGE- S/C F/S GAS
Maytag MGR5750ADQ RANGE- S/C F/S GAS
Maytag MGR5750ADW RANGE- S/C F/S GAS
Maytag MGR5750BDB RANGE- S/C F/S GAS
Maytag MGR5750BDQ RANGE- S/C F/S GAS
Maytag MGR5750BDW RANGE- S/C F/S GAS
Maytag MGR5751ADB RANGE- S/C F/S GAS
Maytag MGR5751ADQ RANGE- S/C F/S GAS
Maytag MGR5751ADS RANGE- S/C F/S GAS
Maytag MGR5751ADW RANGE- S/C F/S GAS
Maytag MGR5751BDB RANGE- S/C F/S GAS
Maytag MGR5751BDQ RANGE- S/C F/S GAS
Maytag MGR5751BDS RANGE- S/C F/S GAS
Maytag MGR5751BDS18 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGR5751BDW RANGE- S/C F/S GAS
Maytag MGR5752ADB RANGE- S/C F/S GAS
Maytag MGR5752ADQ RANGE- S/C F/S GAS
Maytag MGR5752ADS RANGE- S/C F/S GAS
Maytag MGR5752ADW RANGE- S/C F/S GAS
Maytag MGR5752BDB RANGE- S/C F/S GAS
Maytag MGR5752BDQ RANGE- S/C F/S GAS
Maytag MGR5752BDS RANGE- S/C F/S GAS
Maytag MGR5752BDW RANGE- S/C F/S GAS
Maytag MGR5754QDQ RANGE- S/C F/S GAS
Maytag MGR5754QDS RANGE- S/C F/S GAS
Maytag MGR5754QDW RANGE- S/C F/S GAS
Maytag MGR5755ADB RANGE- S/C F/S GAS
Maytag MGR5755ADQ RANGE- S/C F/S GAS
Maytag MGR5755ADW RANGE- S/C F/S GAS
Maytag MGR5755BDB RANGE- S/C F/S GAS
Maytag MGR5755BDQ RANGE- S/C F/S GAS
Maytag MGR5755BDW RANGE- S/C F/S GAS
Maytag MGR5755QDB RANGE- S/C F/S GAS
Maytag MGR5755QDQ RANGE- S/C F/S GAS
Maytag MGR5755QDS RANGE- S/C F/S GAS
Maytag MGR5755QDW RANGE- S/C F/S GAS
Maytag MGR5765QDB RANGE- S/C F/S GAS
Maytag MGR5765QDB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDB2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDQ RANGE- S/C F/S GAS
Maytag MGR5765QDQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDQ2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDS RANGE- S/C F/S GAS
Maytag MGR5765QDS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDS2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDW RANGE- S/C F/S GAS
Maytag MGR5765QDW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5765QDW2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR5770ADA RANGE- S/C F/S GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven heats up to Temp, but wont light back up to keep at temp Pooler Oven Repair (including Ranges and Cooktops) 1 05-06-2014 07:46 AM
Actual Oven Temp Lower Than Set Temp oddie Oven Repair (including Ranges and Cooktops) 0 01-05-2012 05:06 PM
Internal Oven temp 100 degrees hotter than set temp saadragna Oven Repair (including Ranges and Cooktops) 1 11-14-2010 05:52 AM
oven temp selector and temp in oven varies significantly larry68417 Oven Repair (including Ranges and Cooktops) 1 11-12-2010 07:02 PM
Oven temp varies from display temp topxfuelx69 Oven Repair (including Ranges and Cooktops) 0 10-14-2009 01:45 PM
