Discuss
LP stove problems in the winter
 in
Hi everyone, We are at our wits' end with this issue, and hoping we can finally find a solution! The
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » LP stove problems in the winter
  #1 (permalink)
Old 10-22-2013, 07:25 PM
SFL SFL is offline
Junior Member
SFL is on a distinguished road
Default LP stove problems in the winter
Brand: Frigidaire   Age: 5 - 10 years
Hi everyone,
The stove is a Frigidaire, purchased new, and uses propane. It's about six years old. About two years ago, when the weather started to cool in the fall, the stove and oven would fail to light, or would light then go out in about five seconds. During warm weather everything works beautifully. We have replaced the pressure regulator twice and adjusted pressure more times than i can count. Nothing helps until the weather warms up.
Just before this started happening, we had moved the location of the propane tank. It's now about six feet from the house. I have no idea if this is related to the issue or not.
Any ideas and help would be greatly appreciated!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air stove key pad problems sefalk Oven Repair (including Ranges and Cooktops) 5 08-02-2017 05:27 AM
1950's stove - fuse problems? meneermalik Oven Repair (including Ranges and Cooktops) 0 03-28-2013 07:16 AM
Stove problems jacirae_2000 Oven Repair (including Ranges and Cooktops) 1 05-08-2010 04:26 AM
Sterling stove top ignition problems guy belsey Oven Repair (including Ranges and Cooktops) 1 07-01-2009 10:38 PM
Rca Eletric stove problems jolesfamily Oven Repair (including Ranges and Cooktops) 1 04-14-2009 07:57 PM
