I have a GE drop in electric oven. The stove top works and the clock works on the front panel. When you try to use the oven or broil and push the buttons to set the temp the clock just flashes. Could it be the electric control panel in the oven? This is the part number that I got from GE WB27K5140.
I cannot find any info on the given model number. Are you sure it has the "o" in it. Below is for a unit with no o. Parts for GE JMP28GT1AD Range - AppliancePartsPros.comYes the most likely cause is the control board/clock. Unfortunately it looks like it is obsolete so may be difficult to find one. |
THIS FORUM IS DEAD!!!!!!! |
