Discuss
Oven/electric
 in
Turned on oven to bake and saw that the bake element on the bottom of the oven was not getting
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven/electric
  #1 (permalink)
Old 10-12-2009, 12:34 PM
Junior Member
buddio2k is on a distinguished road
Default Oven/electric
Model Number: RS6100XVW   Brand: Whirlpool   Age: More than 10 years
Turned on oven to bake and saw that the bake element on the bottom of the oven was not getting red hot. Broiler element is getting red hot. Disconnected bottom element and it shows 22 ohms at the terminals. Checked from each terminal to element and had no ohm reading. Checked each wire to ground. One shows 120 v and the other wire only 6 volts. What do u recommend could be my problem now?
Thanks in advance.
Ads By Google
Related Models
Whirlpool RS6100XVW0
Whirlpool RS6100XVW1
Whirlpool RS6100XVW2
Whirlpool RS6105XYN0
Whirlpool RS6105XYN1
Whirlpool RS6105XYN2
Whirlpool RS6105XYN3
Whirlpool RS6105XYN4
Whirlpool RS6105XYN5
Whirlpool RS6105XYN6
Whirlpool RS6105XYN7
Whirlpool RS6105XYW0
Whirlpool RS6105XYW1
Whirlpool RS6105XYW2
Whirlpool RS6105XYW3
Whirlpool RS6105XYW4
Whirlpool RS6105XYW5
Whirlpool RS6105XYW6
Whirlpool RS6105XYW7
Whirlpool RS610PXEN0
Whirlpool RS610PXEN2
Whirlpool RS610PXEW0
Whirlpool RS610PXEW2
Whirlpool RS610PXGN0
Whirlpool RS610PXGN1
Whirlpool RS610PXGN2
Whirlpool RS610PXGN3
Whirlpool RS610PXGV10 30" Drop - in Electric Standard Clean Oven
Whirlpool RS610PXGV11 30" Drop - in Electric Standard Clean Oven
Whirlpool RS610PXGV2
Whirlpool RS610PXGV3
Whirlpool RS610PXGV7
Whirlpool RS610PXGV8
Whirlpool RS610PXGV9
Whirlpool RS610PXGW0
Whirlpool RS610PXGW1
Whirlpool RS610PXGW10 30" Drop - in Electric Standard Clean Oven
Whirlpool RS610PXGW11 30" Drop - in Electric Standard Clean Oven
Whirlpool RS610PXGW2
Whirlpool RS610PXGW3
Whirlpool RS610PXGW7
Whirlpool RS610PXGW8
Whirlpool RS610PXGW9
Whirlpool RS610PXK0
Whirlpool RS610PXK1
Whirlpool RS610PXK2
Whirlpool RS610PXK3
Whirlpool RS610PXV0
Whirlpool RS610PXV1
Whirlpool RS610PXV2
Whirlpool RS610PXYH0
Whirlpool RS610PXYH1
Whirlpool RS610PXYH2
Whirlpool RS610PXYH3
Whirlpool RS610PXYH4
General Electric RS622GN1 Electric range
General Electric RS622GP1 Electric range
General Electric RS622GP2BG Electric range
General Electric RS622GP3BG Electric range
Whirlpool RS6300XKW0
Whirlpool RS6300XKW1
Whirlpool RS6300XKW2
Whirlpool RS6300XKW3
Whirlpool RS6300XVN0
Whirlpool RS6300XVN1
Whirlpool RS6300XVN2
Whirlpool RS6300XVW0
Whirlpool RS6300XVW1
Whirlpool RS6300XVW2
Whirlpool RS6305XYN2
Whirlpool RS6305XYN3
Whirlpool RS6305XYN4
Whirlpool RS6305XYN5
Whirlpool RS6305XYN6
Whirlpool RS6305XYW0
Whirlpool RS6305XYW1
Whirlpool RS6305XYW2
Whirlpool RS6305XYW3
Whirlpool RS6305XYW4
Whirlpool RS6305XYW5
Whirlpool RS6305XYW6
Whirlpool RS630PXBH0
Whirlpool RS630PXBH1
Whirlpool RS630PXK0
Whirlpool RS630PXK1
Whirlpool RS630PXK2
Whirlpool RS630PXK3
Whirlpool RS630PXV0
Whirlpool RS630PXV1
Whirlpool RS630PXV2
Whirlpool RS630PXYH0
Whirlpool RS630PXYH1
Whirlpool RS630PXYH2
Whirlpool RS630PXYH3
Whirlpool RS630PXYH4
General Electric RS647G*05 Electric range
General Electric RS647G*H1 Electric range
General Electric RS647G*J1 Electric range
General Electric RS647G*J2 Electric range
General Electric RS647G*J3 Electric range
General Electric RS647G*J4 Electric range
General Electric RS647G*J5 Electric range
General Electric RS647G*J6 Electric range
General Electric RS647G*J8 Electric range
Whirlpool RS660BXBH0
Whirlpool RS660BXBH1
Whirlpool RS660BXBH2
Whirlpool RS660BXK0
Whirlpool RS660BXK1
Whirlpool RS660BXK2
Whirlpool RS660BXK3
Whirlpool RS660BXK4
Whirlpool RS660BXV0
Whirlpool RS660BXV1
Whirlpool RS660BXV2
Whirlpool RS660BXYH0
Whirlpool RS660BXYH1
Whirlpool RS660BXYH2
Whirlpool RS660BXYH3
Whirlpool RS6700XKW0
  #2 (permalink)
Old 10-12-2009, 04:31 PM
Junior Member
Smile
Quote:
Thanks in advance.
Well, after some investigation, I wound up fixing the problem myself. After turning the power off, I lifted up the range top and the pan underneath that. I followed the lead wire that gave my a 6v reading up to the control switch (the switch that turns the oven on bake, broil, timed, etc.) Come to find out that the wire had somehow come loose from the terminal in the back of the switch. It probably happened several days ago while I was cleaning the oven, range top, and the drip pan underneath. Glad I didn't call out a repair man and pay a bunch of cash......and endure the embarassment associated with that! Hope this helps the next homeowner that trys a DIY. Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Upper Oven Handle for GE Electric Oven Oscar Sicola Oven Repair (including Ranges and Cooktops) 0 10-21-2009 07:42 PM
Oven lock switch on Jenn-Air electric oven miriamgreen Oven Repair (including Ranges and Cooktops) 0 10-21-2009 01:40 PM
Electric Oven bgbg24 Oven Repair (including Ranges and Cooktops) 1 03-16-2009 03:41 PM
GE Electric Oven Terry C Oven Repair (including Ranges and Cooktops) 8 11-21-2007 08:15 AM
Electric Oven bunniez Oven Repair (including Ranges and Cooktops) 1 08-21-2007 04:25 PM
