Discuss
gas oven ignitor burns up immediately when installed
 in
I have installed a new ignitor on a Whirlpool gas oven SF375PEWN3 twice and each time it ignited and burned
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » gas oven ignitor burns up immediately when installed
  #1 (permalink)
Old 10-12-2009, 12:07 PM
Junior Member
caldwellczech is on a distinguished road
Default gas oven ignitor burns up immediately when installed
Brand: Whirlpool   Age: 5 - 10 years
I have installed a new ignitor on a Whirlpool gas oven SF375PEWN3 twice and each time it ignited and burned out immediately. I have checked the voltage and it is alright. The broiler works just fine. I have just tried a 3rd ignitor and it started to do the same thing before I disconnected it.
Ads By Google
  #2 (permalink)
Old 10-12-2009, 02:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Have you touched the igniter coil with your fingers?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-12-2009, 04:00 PM
Junior Member
Default
I haven't touched the ignitor with my fingers as I no any oil on it could cause a problem.
  #4 (permalink)
Old 10-13-2009, 01:42 PM
Junior Member
Default
Gene, I haven't touched the ignitor with my fingers do you have any other suggestion to correct the problem
  #5 (permalink)
Old 10-13-2009, 04:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Disconnect the igniter wires and measure the voltage between each wire and ground while the thermostat calls for Bake. Post the results.
What is the part number of the igniter you installed?
__________________
  #6 (permalink)
Old 10-15-2009, 09:20 PM
Junior Member
Default
Haven't tried checking the voltage that way yet. The ignitor part #786324.
  #7 (permalink)
Old 10-16-2009, 02:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Another idea on what could cause this problem - the wire from the gas safety valve to the igniter can be shorted to ground. In such case power to the igniter would not go through the gas safety valve.
Eliminate the wire which goes from the igniter to the gas safety valve and use a new, preferably hi temperature insulated, wire to connect the igniter to the gas safety valve. It should solve the problem.
__________________
  #8 (permalink)
Old 10-21-2009, 07:17 PM
Junior Member
Default whirlpool gas oven ignitor burns up
Gene, Does a shorted gas valve cause the ignitor to get to much current and burn out. The gas valve is shorted.
  #9 (permalink)
Old 10-22-2009, 04:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It's not shorted. There is a bi-metal inside the gas valve which shows close to 0 Ohms resistance. It is normal unless it's sorted to the ground. Have you checked that wire?
__________________
  #10 (permalink)
Old 10-22-2009, 06:42 PM
Junior Member
Don't understand how that ground could be shorted since it is not touching anything.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore oven GE installed 1997 gamak51 Oven Repair (including Ranges and Cooktops) 0 01-22-2010 08:05 AM
Viking Oven Burns Everything pattyjackmore Oven Repair (including Ranges and Cooktops) 1 01-08-2010 08:49 AM
Kitchenaid Superba Ignitor installed still won't heat pbanspach Oven Repair (including Ranges and Cooktops) 1 06-04-2009 02:31 PM
Gas Oven - randomly burns food- Thermostat? dave12345 Oven Repair (including Ranges and Cooktops) 1 12-29-2008 09:57 AM
Gas oven burns dirty jhealey Oven Repair (including Ranges and Cooktops) 1 09-10-2007 06:40 PM
