Discuss
won't light
 in
thermador Knobs will not light burners. They use to click then burner would light. The igniters would click, now we
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » won't light
  #1 (permalink)
Old 02-11-2008, 11:06 AM
raymo@57 raymo@57 is offline
Junior Member
raymo@57 is on a distinguished road
Default won't light
Model Number: PCS364GL   Brand: Thermador   Age: 5 - 10 years
thermador Knobs will not light burners. They use to click then burner would light. The igniters would click, now we light them with a lighter. They don't click, and griddle doesn't get hot know either. thank you
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-11-2008, 06:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is 120V at the power outlet and the plug connection.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-11-2008, 07:00 PM
Junior Member
Default won't light
the electric is good the ignitor's on all 4 burners worked on and off then they went out all together. Then one day they just started woking again and then a few day's later they went out! what do you think
  #4 (permalink)
Old 02-11-2008, 08:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you check the outlet or you just think it's good?
__________________
  #5 (permalink)
Old 02-29-2008, 09:31 AM
Servicer Servicer is offline
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
Does the red light near the left side burners light up, or does gas flow from the left side burners when it's not sparking?
If not, then Gene is on the right track, and it sounds like a power supply issue. You can use and extension cord and plug it into a known-good outlet and test it. Or it could also be a simmer control starting to go bad. This component sends power to the spark module to start the sparking.
If the light does turn on every time there may be a problem with the spark module.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cna't light pliot light Rosanne Oven Repair (including Ranges and Cooktops) 0 11-21-2007 10:27 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
