Hello pros! My Kitchen Aid oven works fine when it has completely cooled down. At least 5 hrs.Turn it on to bake and it will work all day. If I turn it on to bake within a couple of hrs. of use or if I have used it to say warm at 200 and then turn it up to say 350 to bake the oven won't heat up past the second notch. I have replaced the temp sensor and the control behind the knobs. Your expertise is greatly appreciated Thank Don
