I have a Maytag gas oven model # MGR5875QDS that reaches set oven temperature; beeps that temperature is reached (using oven thermometer) and shortly after continues to 50-75 degrees above desired temperature. Non-desired temperature fluctuates but never returns down to set temp. I replaced oven thermostat and symptoms did not change. Please advise.
