Discuss
Set Cavity Size on new control
 in
I recently replaced the control, W10438752, on a Kitchen Aid double convection oven (KEBC278KBL030). Tech sheet in the oven controls
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Set Cavity Size on new control
  #1 (permalink)
Old 10-07-2013, 10:32 AM
JTV JTV is offline
Junior Member
JTV is on a distinguished road
Default Set Cavity Size on new control
Model Number: KEBC278KBL030   Brand: Kitchen Aid   Age: 5 - 10 years
I recently replaced the control, W10438752, on a Kitchen Aid double convection oven (KEBC278KBL030). Tech sheet in the oven controls compartment stated that a new control needed to be matched to oven size on first start up by pushing a number of buttons: Bake, Conv Broil, etc and then set the oven size. This did not work as described and there was no able to set the size to 27. I believe it arrives defaulted to 30". Has the start-up procedure changed for repair parts? There were no instructions sent with the part. Control seems to work, but oven temp needed to be reduced 25F (set point 350 with actual 375).
Related Models
Whirlpool KEBC278KBL04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBL1 DOUBLE OVEN
Whirlpool KEBC278KBS0 OVEN
Whirlpool KEBC278KBS1 DOUBLE OVEN
Whirlpool KEBC278KBT0 OVEN
Whirlpool KEBC278KBT02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBT03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBT04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBT1 DOUBLE OVEN
Whirlpool KEBC278KSS0 OVEN
Whirlpool KEBC278KSS02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KSS03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KSS1 DOUBLE OVEN
Whirlpool KEBC278KWH0 OVEN
Whirlpool KEBC278KWH02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KWH03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KWH1 DOUBLE OVEN
Whirlpool KEBI100BBL0 30" ELEC BUILT-IN OVEN
Whirlpool KEBI100BBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH0 30" ELECTRIC OVEN
Whirlpool KEBI100BWH1 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100TBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL2 ELECTRIC RANGE
Whirlpool KEBI100VBL3 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100WWH0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100YBL0 ELEC. BUILT-IN OVEN
Whirlpool KEBI100YBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100YBL3 30" ELEC BUILT-IN OVEN
Whirlpool KEBI100YWH0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100YWH2 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100YWH3 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI101DBL1 ELECTRIC RANGE
Whirlpool KEBI101DBL10 ELECTRIC OVEN
Whirlpool KEBI101DBL11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBI101DBL12 BUILT IN OVEN
Whirlpool KEBI101DBL2 BUILT IN OVENS
Whirlpool KEBI101DBL4 BUILT IN OVEN
Whirlpool KEBI101DBL6 OVEN
Whirlpool KEBI101DBL7 OVEN
Whirlpool KEBI101DBL8 ELECTRIC OVEN
Whirlpool KEBI101DBL9 ELECTRIC OVEN
Whirlpool KEBI101DWH1 ELECTRIC RANGE
Whirlpool KEBI101DWH10 ELECTRIC OVEN
Whirlpool KEBI101DWH11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBI101DWH12 BUILT IN OVEN
Whirlpool KEBI101DWH2 ELECTRIC BUILT IN OVEN
Whirlpool KEBI101DWH4 BUILT IN OVEN
Whirlpool KEBI101DWH6 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Whirlpool KEBI101DWH7 OVEN
Whirlpool KEBI101DWH8 ELECTRIC OVEN
Whirlpool KEBI101DWH9 ELECTRIC OVEN
KitchenAid KEBI107DWH10 BUILT-IN ELECTRIC OVEN
Whirlpool KEBI140SBL0 ELECTRIC RANGES & OVENS
Whirlpool KEBI140SBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI141BBL0 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBI141BBL1 24" BUILT-IN ELECTRIC SELF CLEAN OVEN
Whirlpool KEBI141BBL2 IMPERIAL 24" BUILT-IN ELECTRIC SELF CLEAN OVEN
Whirlpool KEBI141BBL3 24" BUILT-IN ELECTIC OVEN
Whirlpool KEBI141BWH0 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBI141BWH1 24" BUILT-IN ELECTRIC SELF CLEAN OVEN
Whirlpool KEBI141BWH2 IMPERIAL 24" BUILT-IN ELECTRIC SELF CLEAN OVEN
Whirlpool KEBI141BWH3 24" BUILT-IN ELECTIC OVEN
Whirlpool KEBI141DBL1 Built-In Oven, Electric
Whirlpool KEBI141DBL10 OVEN
Whirlpool KEBI141DBL11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBI141DBL2 Built-In Oven, Electric
Whirlpool KEBI141DBL4 24" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool KEBI141DBL6 24" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBI141DBL7 OVEN
Whirlpool KEBI141DBL8 ELECTRIC OVEN
Whirlpool KEBI141DBL9 OVEN
Whirlpool KEBI141DWH1 Built-In Oven, Electric
Whirlpool KEBI141DWH10 OVEN
Whirlpool KEBI141DWH11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBI141DWH2 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBI141DWH4 24" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool KEBI141DWH6 24" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBI141DWH7 OVEN
Whirlpool KEBI141DWH8 ELECTRIC OVEN
Whirlpool KEBI141SBL0 Ranges, Electric*
KitchenAid KEBI141SBL1 Ranges, Electric*
Whirlpool KEBI141WBL0 Ranges, Electric*
Whirlpool KEBI141WBL1 Ranges, Electric*
Whirlpool KEBI141WBL2 Ranges, Electric*
Whirlpool KEBI141WBL3 Ranges, Electric*
Whirlpool KEBI141XBL0 Ranges, Electric*
Whirlpool KEBI141XBL1 Ranges, Electric*
Whirlpool KEBI141YBL0
Whirlpool KEBI141YBL1 Ranges, Electric*
Whirlpool KEBI141YBL2 Ranges, Electric*
Whirlpool KEBI141YBL4 24" ELEC BUILT-IN OVEN
Whirlpool KEBI141YWH0 Ranges, Electric*
Whirlpool KEBI141YWH1 Ranges, Electric*
Whirlpool KEBI141YWH3 Ranges, Electric*
Whirlpool KEBI141YWH4 Ranges, Electric*
Whirlpool KEBI170SBL0 ELECTRIC RANGES & OVENS
Whirlpool KEBI170SBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI171BBL0 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBI171BBL1 27" BUILT-IN ELECTRIC SINGLE SELF CLEAN OVEN
Whirlpool KEBI171BBL2 IMPERIAL 27" BUILT-IN ELECTRIC SINGLE SELF-CLEAN OVEN
Whirlpool KEBI171BBL3 27" BUILT-IN ELECTRIC SINGLE SELF CLEAN OVEN
Whirlpool KEBI171BWH0 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBI171BWH1 27" BUILT-IN ELECTRIC SINGLE SELF CLEAN OVEN
Whirlpool KEBI171BWH2 IMPERIAL 27" BUILT-IN ELECTRIC SINGLE SELF-CLEAN OVEN
Whirlpool KEBI171DBL1 ELECTRIC RANGE
Whirlpool KEBI171DBL10 BUILT IN OVEN
Whirlpool KEBI171DBL11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBI171DBL2 ELECTRIC RANGE
Whirlpool KEBI171DBL4 ELECTRIC RANGES & OVENS
Whirlpool KEBI171DBL6 27" BUILT-IN ELECTRIC SINGLE OVEN SELF CLEAN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool cavity size davandvic Oven Repair (including Ranges and Cooktops) 0 11-15-2009 06:29 PM
New control panel setting oven cavity size bwoods94566 Oven Repair (including Ranges and Cooktops) 0 06-24-2009 10:48 AM
Cavity size calculation widget925 Oven Repair (including Ranges and Cooktops) 2 04-28-2009 03:28 AM
Cavity size calculation widget925 Oven Repair (including Ranges and Cooktops) 0 04-25-2009 12:45 PM
looking for cavity bomaro Microwave Repair 0 03-13-2009 03:43 PM
