Jenn Air Elec Range, Dual Element Not Working
I hope you can help me. The left/front surface element of our Jenn-Air electric range (Model No.: JER8885RAF, Serial No.:
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Air Elec Range, Dual Element Not Working
  #1 (permalink)
Old 10-03-2013, 09:17 PM
Junior Member
slauer is on a distinguished road
Default Jenn Air Elec Range, Dual Element Not Working
Model Number: JER8885RAF,   Brand: Jenn-Air   Age: 5 - 10 years
(Model No.: JER8885RAF, Serial No.: 1239660LF) does not turn on but the
"element on" LED lights up when the switch/knob is turned in either
direction. This element is controlled by the left most switch and the
burner is a "Dual Ultra High/Low" surface element. I ordered a replacement
surface element (7406P403-60) and switch (74010824) from
AppliancePartsPros.com and received what looked like the incorrect parts.
My surface element has a sensor in the element and a black wire with a
wire harness connector. The element infinity switch is black (not white)
with two (2) rectangular cable connectors plugged into the switch. The top
plug has 6 wires (orange, tan black, black, blue, yellow) and the bottom
plug has two wires (red/red) connected to the first position and two wires
(black/black) connect to the last position. Looking from the back, my
orientation is left to right.
After I removed the glass top surface from the range and before I noticed
that I had the wrong parts, I made some resistance readings on the original
element. The internal element windings seem to connect to three (3) pins
on the outside of the surface next to the input electrical connector. If I
call the 3 pins A B and C, where A and B have connected wires and C is
connected to the input electrical connector. The sequence is A, B, C, and
then the input connector.
The resistance readings I obtained were:
A to B: 68 Ohms
B to C: 37 Ohms
A to C: 32 Ohms
where A B and C represent the left, middle, and right terminals of the
surface element.
Also, looking at the nine (9) pin harness connector from the range top, one
of the pins on the pins seems to be dis-colored. This pin is in the upper
right position and is bare where all the other pins are in a plastic sleeve.
The pin doesn't smell burnt and I was able to get connectivity between the
connector and the surface element. I was not able to check the other end.
I did not take any resistance readings at the infinity switch.
Do you think my problem is the switch, element, or something else?
Hopefully, you can help me trouble-shoot this problem.
Related Models
General Electric JES0601T01 GE MICROWAVE OVENS, COUN
General Electric JES0601T010 Counter top microwave
General Electric JES0601T011 Counter top microwave
General Electric JES0601T012 Counter top microwave
General Electric JES0601T02 Counter top microwave
General Electric JES0601T03 Counter top microwave
General Electric JES0734PM1RR MICROWAVE
General Electric JES0736SM1SS MICROWAVE
General Electric JES0736SM2SS MICROWAVE
General Electric JES0736SM3SS MICROWAVE
General Electric JES0736SP1SS MICROWAVE
General Electric JES0737DN1BB MICROWAVE
General Electric JES0737DN1WW MICROWAVE
General Electric JES0737DN2BB MICROWAVE
General Electric JES0737DN2WW MICROWAVE
General Electric JES0738DP1BB MICROWAVE
General Electric JES0738DP1WW MICROWAVE
General Electric JES1022TW01 Counter top microwave
General Electric JES1022TW02 Counter top microwave
General Electric JES1022TW03 Counter top microwave
General Electric JES1022TW04 Counter top microwave
General Electric JES1030TP01 Counter top microwave
General Electric JES1030TW01 Counter top microwave
General Electric JES1030TW02 Counter top microwave
General Electric JES1031TW01 Counter top microwave
General Electric JES1031TW02 Counter top microwave
General Electric JES1033BA01 Counter top microwave
General Electric JES1033BB01 Counter top microwave
General Electric JES1033WA01 Counter top microwave
General Electric JES1033WB01 Counter top microwave
General Electric JES1034WF001 Counter top microwave
General Electric JES1034WF02 Counter top microwave
General Electric JES1036BK01 Counter top microwave
General Electric JES1036NL01 Counter top microwave
General Electric JES1036PWF001 Counter top microwave
General Electric JES1036PWH001 Counter top microwave
General Electric JES1036PWH002 Counter top microwave
General Electric JES1036PWH03 Counter top microwave
General Electric JES1036WF001 Counter top microwave
General Electric JES1036WF002 Counter top microwave
General Electric JES1036WF03 Counter top microwave
General Electric JES1036WK01 Counter top microwave
General Electric JES1036WK02 Counter top microwave
General Electric JES1039BJ01 Counter top microwave
General Electric JES1039BJ02 Counter top microwave
General Electric JES1039WF001 Counter top microwave
General Electric JES1039WJ01 Counter top microwave
General Electric JES1039WJ02 Counter top microwave
General Electric JES1130DS1BB MICROWAVE
General Electric JES1130DS1WW MICROWAVE
General Electric JES1131GB002 Counter top microwave
General Electric JES1131GB01 Counter top microwave
General Electric JES1131WC002 Counter top microwave
General Electric JES1133PN01 Counter top microwave
General Electric JES1133PN02 Counter top microwave
General Electric JES1133PN03 Counter top microwave
General Electric JES1133WD01 Counter top microwave
General Electric JES1133WN01 Counter top microwave
General Electric JES1133WN02 Counter top microwave
General Electric JES1133WN03 Counter top microwave
General Electric JES1133WN04 Counter top microwave
General Electric JES1133WN05 Counter top microwave
General Electric JES1133WN06 Counter top microwave
General Electric JES1133WNP01 Counter top microwave
General Electric JES1133WNP02 Counter top microwave
General Electric JES1133WNP03 Counter top microwave
General Electric JES1134WN01 Counter top microwave
General Electric JES1134WN02 Counter top microwave
General Electric JES1134WN03 Counter top microwave
General Electric JES1134WN04 Counter top microwave
General Electric JES1136WK01 Counter top microwave
General Electric JES1136WL01 Counter top microwave
General Electric JES1136WL02 MICROWAVE
General Electric JES1139BL01 Counter top microwave
General Electric JES1139BL02 MICROWAVE
General Electric JES1139BL03 MICROWAVE
General Electric JES1139DS1BB MICROWAVE
General Electric JES1139DS1WW MICROWAVE
General Electric JES1139WL01 Counter top microwave
General Electric JES1139WL02 MICROWAVE
General Electric JES1139WL03 MICROWAVE
General Electric JES1140SP1SS MICROWAVE
General Electric JES1142SF001 Counter top microwave
General Electric JES1142SF02 Counter top microwave
General Electric JES1142SJ01 Counter top microwave
General Electric JES1142SJ02 Counter top microwave
General Electric JES1142SJ03 Counter top microwave
General Electric JES1142SJ04 Counter top microwave
General Electric JES1142SJ05 MICROWAVE
General Electric JES1142SJ06 MICROWAVE
General Electric JES1142SP1SS MICROWAVE
General Electric JES1142WD001 Counter top microwave
General Electric JES1142WD02 Counter top microwave
General Electric JES1142WD03 Counter top microwave
General Electric JES1142WD04 Counter top microwave
General Electric JES1142WD05 MICROWAVE
General Electric JES1143WW01 Counter top microwave
General Electric JES1143WW02 Counter top microwave
General Electric JES1143WWP01 Counter top microwave
General Electric JES1144WY01 Counter top microwave
General Electric JES1144WY02 Counter top microwave
General Electric JES1144WY03 Counter top microwave
General Electric JES1144WYP01 Counter top microwave
General Electric JES1145DP1BB MICROWAVE
General Electric JES1145DP1WW MICROWAVE
General Electric JES1146BF001 Counter top microwave
General Electric JES1152DP1BB MICROWAVE
General Electric JES1152DP1WW MICROWAVE
General Electric JES1160DP1BB MICROWAVE
General Electric JES1160DP1WW MICROWAVE
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air range dual element burner limiter rterrass Oven Repair (including Ranges and Cooktops) 1 03-18-2011 02:40 AM
repairing burner in jenn-air elec range jimfaust Oven Repair (including Ranges and Cooktops) 1 03-16-2011 04:45 AM
Jenn-air cooktop dual element wporter Oven Repair (including Ranges and Cooktops) 1 12-29-2009 12:18 PM
jenn air dual element does not heat ajax5777 Oven Repair (including Ranges and Cooktops) 1 06-28-2009 01:23 PM
Jenn-Air front right dual element won't back off high nujer Oven Repair (including Ranges and Cooktops) 2 02-26-2009 01:12 PM
