Discuss
Fault codes F7 and F3
 in
I have a Maytag model # CWG3100 AAE serial # 2555 7737 CN wall gas oven. I have been getting
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Fault codes F7 and F3
  #1 (permalink)
Old 10-02-2013, 09:30 AM
Junior Member
Sgavin is on a distinguished road
Default Fault codes F7 and F3
Model Number: CWG3100   Brand: Maytag   Age: 5 - 10 years
I have been getting a fault code of F7 for a while which I believe relates to the ERC board.
Sometimes the oven works fine without any problems. When I get the fault code F7 , I can wait about ten minutes or so and start again, and most of the time I can finish the baking without getting another F7. If, after I get F7, I restart immediately without waiting, it produces F7 immediately. Recently, I have also been getting F3 as well which I believe is the temperature sensor. Can the two problems be related? Do I just replace both parts?
Related Models
Maytag CWG3100AAB WALLOVEN- STD GAS
Maytag CWG3100AAB25 24" BUILT-IN GAS OVEN
Maytag CWG3100AAE WALLOVEN- STD GAS
Maytag CWG3100AAE29 24" BUILT-IN GAS OVEN
Maytag CWG3100AAS WALLOVEN- STD GAS
Maytag CWG3100AAS13 24" BUILT-IN GAS OVEN
Maytag CWG351 WALLOVEN- STD GAS
Maytag CWG3510AAB WALLOVEN- STD GAS
Maytag CWG3510BAB WALLOVEN- STD GAS
Maytag CWG3600AAB WALLOVEN- STD GAS
Maytag CWG3600AAB26 24" BUILT-IN GAS OVEN
Maytag CWG3600AAS WALLOVEN- STD GAS
Maytag CWG3600AAS13 24" BUILT-IN GAS OVEN
Maytag CWG400 WALLOVEN- STD GAS
Maytag CWG401 WALLOVEN- STD GAS
Maytag CWG402 WALLOVEN- CONT CLEAN GAS
Maytag CWG4020AAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4020BAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4100AAB WALLOVEN- STD GAS
Maytag CWG450 WALLOVEN- STD GAS
Maytag CWG451 WALLOVEN- CONT CLEAN GAS
Maytag CWG4510AAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4510BAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4600AAB WALLOVEN- STD GAS
Admiral CWGA200AAB WALLOVEN- CONT CLEAN GAS
Admiral CWGA800AAB WALLOVEN- S/C GAS
Admiral CWGA800AAE WALLOVEN- S/C GAS
Frigidaire CWS3600AS0 Fs Washer - Frig/best Buy
Frigidaire CWS3600AS1 Frigidaire/washer
Frigidaire CWS445RGS0 Gib(v0) / Free Standing Washer
Frigidaire CWS445RGS1 Gib(v0) / Free Standing Washer
Maytag CX8670RB SURFACE UNIT- ELE
Maytag CX8670RV SURFACE UNIT- ELE
Maytag CX8670TB SURFACE UNIT- ELE
Maytag CX8670TV SURFACE UNIT- ELE
Maytag CX9875VVV WALLOVEN- S/C ELE
Maytag CX9875VYV WALLOVEN- S/C ELE
Maytag CX9875XYB WALLOVEN- S/C ELE
Admiral CYE1000AYW DRYER- ELE
Admiral CYE2000AKW DRYER- ELE
Magic Chef CYE2000AYA DRYER- ELE
Magic Chef CYE2000AYW DRYER- ELE
Magic Chef CYE2000AZW DRYER- ELE
Admiral CYE3004AGW DRYER- ELE
Admiral CYE3004AKW DRYER- ELE
Magic Chef CYE3004AYW DRYER- ELE
Magic Chef CYE3004AZW DRYER- ELE
Admiral CYE3005AGW DRYER- ELE
Magic Chef CYE3005AKW DRYER- ELE
Magic Chef CYE3005AYW DRYER- ELE
Magic Chef CYE3005AZW DRYER- ELE
Admiral CYE4000AGW DRYER- ELE
Magic Chef CYE4000AYA DRYER- ELE
Magic Chef CYE4000AYS DRYER- ELE
Magic Chef CYE4000AYW DRYER- ELE
Magic Chef CYE4000AZS DRYER- ELE
Magic Chef CYE4000AZW DRYER- ELE
Admiral CYG1000AWW DRYER- GAS
Magic Chef CYG1005AWW DRYER- GAS
Magic Chef CYG2000AWA DRYER- GAS
Magic Chef CYG2000AWW DRYER- GAS
Magic Chef CYG3004AWW DRYER- GAS
Magic Chef CYG3005AWW DRYER- GAS
Magic Chef CYG4000AWA DRYER- GAS
Magic Chef CYG4000AWS DRYER- GAS
Magic Chef CYG4000AWW DRYER- GAS
Hardwick D-150 RANGE- F/S STD ELE
Hardwick D-170 RANGE- F/S STD ELE
Hardwick D-445 SURFACE UNIT- ELE
Hardwick D-456 SURFACE UNIT- ELE
Hardwick D-950 RANGE- F/S STD ELE
Amana D1150.000 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air D120 RANGE- D/I STD DDRAFT ELE
Amana D1200 MWAVE - FAMILY SIZE (60 HZ)
Amana D1250 MWAVE - FAMILY SIZE (60 HZ)
Amana D1270.000 MWAVE - FAMILY SIZE (60 HZ)
Amana D1280.000 MWAVE - FAMILY SIZE (60 HZ)
Amana D13F FREEZER- VERTICAL
Frigidaire D13FA0 Frg(v2) / Refrigerator
Frigidaire D13FF0 Frg(v4) / Refrigerator
Frigidaire D13FH0 Frg(v3) / Refrigerator
Frigidaire D13FL0 Frg(v5) / Refrigerator
Frigidaire D13FW0 Frg(v1) / Refrigerator
Frigidaire D13MA8 Frg(v2) / Refrigerator
Frigidaire D13MF8 Frg(v4) / Refrigerator
Frigidaire D13MH8 Frg(v3) / Refrigerator
Frigidaire D13ML7 Frg(v1) / Refrigerator
Frigidaire D13ML8 Frg(v5) / Refrigerator
Frigidaire D13MW7 Frg(v2) / Refrigerator
Frigidaire D13MW8 Frg(v1) / Refrigerator
Jenn-Air D140 RANGE- S/I STD DDRAFT ELE
Jenn-Air D140-C RANGE- S/I STD DDRAFT ELE
Jenn-Air D146 RANGE- S/C D/I DDRAFT ELE
Jenn-Air D146-C RANGE- S/C D/I DDRAFT ELE
Jenn-Air D146B Range - S/c D/i Ddraft Ele
Jenn-Air D146W RANGE- S/C D/I DDRAFT ELE
Jenn-Air D156 RANGE- S/C D/I ELE
Jenn-Air D156B RANGE- S/C D/I ELE
Jenn-Air D156W RANGE- S/C D/I ELE
Amana D16C FREEZER- VERTICAL
Amana D18E FREEZER- VERTICAL
Whirlpool D200 DEHUMIDIFIER
Amana D23B FREEZER- VERTICAL
Whirlpool D25A0 DEHUMIDIFIER
Whirlpool D25A1 DEHUMIDIFIER
Whirlpool D25A2 DEHUMIDIFIER
Whirlpool D25B0 DEHUMIDIFIER
Whirlpool D300 DEHUMIDIFIER
Frigidaire D3000 Gib(v1) / Food Disposer
Frigidaire D3001 Gib(v2) / Food Disposer
Whirlpool D30A0 DEHUMIDIFIER
Whirlpool D30A1 DEHUMIDIFIER
Whirlpool D30A2 DEHUMIDIFIER
Whirlpool D30A3 DEHUMIDIFIER
Whirlpool D30B0 DEHUMIDIFIER
Maytag D31100PAAL RANGE- F/S STD GAS
Maytag D31100PATL RANGE- F/S STD GAS
Maytag D31100PAWL RANGE- F/S STD GAS
Maytag D31100SAAL RANGE- F/S STD GAS
Maytag D31100SAWL RANGE- F/S STD GAS
  #2 (permalink)
Old 10-02-2013, 06:01 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
F7 code usually means a stuck key on the key pad. Some of the keys can be unstuck, but if high heat caused the pad to warp it might not be repairable.
  • Turn off power
  • Disconnect the key pad from the clock
    • If code goes away key pad is at fault
    • If it does not the EOC (electronic control board) is at fault
You can try giving the oven a hard reset by disconnecting the power for 20-30 minutes, then restoring the power.
If you do not feel comfortable diagnosing the problem yourself, I recommend having a tech come out to repair your appliance
F3 Is a bad temp sensor or connection replace sensor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F70 & F71 fault codes krocheleau Washer Repair 0 07-15-2013 09:58 AM
Fault Codes When Not in Use sb129 Oven Repair (including Ranges and Cooktops) 0 11-12-2011 07:42 AM
fault codes rjreiner Washer Repair 1 03-14-2011 12:25 PM
fault codes shepp59 Oven Repair (including Ranges and Cooktops) 3 11-18-2010 05:20 PM
F1-1, F1-2, F3-2 Fault Codes pjc97009 Oven Repair (including Ranges and Cooktops) 0 11-15-2010 01:47 PM
