Discuss
electric range oven not heating
 in
Neither of the oven elements are heating in an oven that has been used little. This sounds like no power
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » electric range oven not heating
  #1 (permalink)
Old 10-01-2013, 10:51 AM
Junior Member
jcs44 is on a distinguished road
Default electric range oven not heating
Model Number: FEP310VQ   Brand: Roper   Age: 1 - 5 years
Neither of the oven elements are heating in an oven that has been used little. This sounds like no power to either element which sounds like a control or thermostat problem. Any advice appreciated.
Newby, jcs44
Related Models
Roper FEP310VQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310VW0 Ranges, Electric*
Roper FEP310VW1 Ranges, Electric*
Roper FEP310YW0 Ranges, Electric*
Roper FEP310YW1 Ranges, Electric*
Roper FEP310YW2 Ranges, Electric*
Roper FEP314BL0 30" ELECTRONIC RANGE / OVEN
Roper FEP314BW0 30" ELECTRONIC RANGE / OVEN
Roper FEP320BL0 ELECTRIC RANGE
Roper FEP320BL1 ELECTRIC RANGE
Roper FEP320BW0 ELECTRIC RANGE
Roper FEP320BW1 ELECTRIC RANGE
Roper FEP320EN0 ELECTRIC RANGE
Roper FEP320EN1 ELECTRIC RANGE
Roper FEP320EW0 ELECTRIC RANGE
Roper FEP320EW1 ELECTRIC RANGE
Roper FEP320GN0 ELECTRIC RANGE
Roper FEP320GN1 ELECTRIC RANGE
Roper FEP320GW0 ELECTRIC RANGE
Roper FEP320GW1 ELECTRIC RANGE
Roper FEP320KN0 ELECTRIC RANGE
Roper FEP320KN1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP320KW0 ELECTRIC RANGE
Roper FEP320KW1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP320VW0 ELECTRIC RANGE
Roper FEP320YW0 ELECTRIC RANGE
Roper FEP320YW1 ELECTRIC RANGE
Roper FEP320YW2 ELECTRIC RANGE
Roper FEP330BL0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330BL1 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330BQ0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330BQ1 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330BW0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330BW1 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330EN0 ELECTRIC RANGE
Roper FEP330EN1 ELECTRIC RANGES AND OVENS
Roper FEP330EQ0 ELECTRIC RANGE
Roper FEP330EQ1 ELECTRIC RANGES AND OVENS
Roper FEP330EW0 ELECTRIC RANGE
Roper FEP330EW1 ELECTRIC RANGES AND OVENS
Roper FEP330GN0 30" ELECTRIC FREESTANDING RANGE
Roper FEP330GN1 ELECTRIC RANGE
Roper FEP330GQ0 30" ELECTRIC FREESTANDING RANGE
Roper FEP330GQ1 ELECTRIC RANGE
Roper FEP330GW0 30" ELECTRIC FREESTANDING RANGE
Roper FEP330GW1 ELECTRIC RANGE
Roper FEP330KN0 ELECTRIC RANGE
Roper FEP330KN1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP330KQ0 ELECTRIC RANGE
Roper FEP330KQ1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP330KW0 ELECTRIC RANGE
Roper FEP330KW1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP330VW0 Ranges, Electric
Roper FEP330VW1 Ranges, Electric
Roper FEP330YW0 Ranges, Electric
Roper FEP330YW1 Ranges, Electric
Roper FEP330YW2 Ranges, Electric
Roper FEP340VW0 Ranges, Electric*
Roper FEP340YW0 Ranges, Electric*
Roper FEP340YW1 Ranges, Electric*
Roper FEP350BL0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP350BW0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP350BW1 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP350VW0 Ranges, Electric*
Roper FEP350YW0 Ranges, Electric*
Roper FEP350YW1 Ranges, Electric*
Roper FEP350YW2 Ranges, Electric*
Frigidaire FEQ1442CES0 Frigidaire/dryer
Frigidaire FEQ1442CES1 DRYER
Frigidaire FEQ1442ES0 Frigidaire/dryer
Frigidaire FEQ1442ES1 DRYER
Frigidaire FEQ1442FE0 DRYER
Frigidaire FEQ1452CKS0 ELECTRIC DRYER
Frigidaire FEQ1452HE0 DRYER
Frigidaire FEQ1452HS0 DRYER
Frigidaire FEQ332CES0 Frigidaire/dryer
Frigidaire FEQ332ES0 Frigidaire/dryer
Frigidaire FEQ5000HS0 DRYER
Frigidaire FEQB2152FE0 Frigidaire/dryer
Frigidaire FEQB2152FE1 DRYER
Frigidaire FEQB4000FS0 Frigidaire/dryer
Frigidaire FEQB4000FS1 FRIGIDAIRE/DRYER
Frigidaire FEQBB30DS0 Frigidaire/dryer
Frigidaire FER111AS0 Dryer - Frigidaire
Frigidaire FER111AS1 Dryer - Frigidaire
Frigidaire FER111AS2 Frigidaire/electric Dryer
Frigidaire FER211AS0 Dryer - Frigidaire
Frigidaire FER211AS1 Dryer - Frigidaire
Frigidaire FER211AS2 Frigidaire/dryer
Frigidaire FER221AS0 Dryer - Frigidaire
Frigidaire FER231AS0 Dryer - Frigidaire
Frigidaire FER231AS1 Dryer - Frigidaire
Frigidaire FER231AS2 Frigidaire/electric Dryer
Frigidaire FER311CFS0 Frigidaire/dryer
Frigidaire FER311FS0 Frigidaire/dryer
Frigidaire FER331AS0 Dryer - Frigidaire
Frigidaire FER331AS1 Dryer - Frigidaire
Frigidaire FER331KAS1 Frigidaire/dryer
Frigidaire FER341AC0 Frigidaire/dryer
Frigidaire FER341AS0 Dryer - Frigidaire
Frigidaire FER341AS1 Dryer - Frigidaire
Frigidaire FER641CFS0 Frigidaire/dryer
Frigidaire FER641FS0 DRYER
Frigidaire FER6600ES0 Frigidaire/dryer
Frigidaire FER6600FS0 Frigidaire/dryer
Frigidaire FERB5700DS0 Frigidaire/dryer
Frigidaire FERB6600ES0 Frigidaire/dryer
Frigidaire FERB6600FS0 Frigidaire/dryer
Frigidaire FERB7800DS0 Frigidaire/dryer
Frigidaire FES300ASA Frigidaire/electric Range
Frigidaire FES300ASB Frigidaire/electric Range
Frigidaire FES300ASC Frigidaire/electric Range
Frigidaire FES300ASD Frigidaire/electric Range
Frigidaire FES300ASE Frigidaire/electric Range
Frigidaire FES300ASF Frigidaire/electric Range
Frigidaire FES300BEBA Frg(v0) / Electric Range
Frigidaire FES300BEBB Frg(v0) / Electric Range
Frigidaire FES300BEBC Frg(v0) / Electric Range
Frigidaire FES300DSA Frigidaire/electric Range
Frigidaire FES300DSB Frigidaire/electric Range
  #2 (permalink)
Old 10-02-2013, 06:12 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Roper FEP310VQ0 Range - AppliancePartsPros.com
See the attachment ffor the wiring diagram.
I am assuming that the stove top elements work OK.
Does the oven stay in preheat and never comes ready.
If it shows that it is ready then it could be a control board or a oven sensor problem. I am not sure if the unit has a preheat/ready indication. Note that you cannot go by the Oven Heating Light as that just shows if the elements are on.
Check the wiring to/from the heating elements.
The wiring diagram shows a Thermal Cut-off in the element circuit but I could not find one in the parts so I do not know if there actually is one in the unit.
it does say Canada only.
If there is it is most commonly mounted to the outside back of the oven.
it should measure 0 ohms (closed).
Check the oven sensor it should be about 1100 ohms.
Note that if the unit stays in preheat then it is not a sensor problem.
If all OK then I would say that your control board is shot.
Be sure to unplug the unit when working on it.
__________________
  #3 (permalink)
Old 10-02-2013, 06:24 AM
Junior Member
Default
Thanks for this detailed response! I did some further checks on it. It turns out that the broiler section does work and when in that mode, the oven light on the panel is on. However, when the oven switch is turned to bake, the light stays off and no power is getting to the bake element. The bake element checks OK on an ohm meter. There is no preheat function. Makes me think the control/switch is the problem. Comments?
  #4 (permalink)
Old 10-02-2013, 06:41 AM
Senior Expert
APP Volunteer
Default
I agree with you.
I would check the wiring to it just to be sure.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric Range Oven not heating properly JohnDavidson Oven Repair (including Ranges and Cooktops) 0 10-23-2012 01:29 PM
Whirlpool Electric Range Not Heating Up Mikecass Oven Repair (including Ranges and Cooktops) 1 05-02-2011 04:02 PM
Roper Electric Range - All Elements Not Heating jables Oven Repair (including Ranges and Cooktops) 4 12-02-2010 01:53 AM
GE JBP26WY6 Electric range not heating Stealth7 Oven Repair (including Ranges and Cooktops) 0 09-24-2009 12:24 PM
ge electric range f4 error code when heating oven terraglio Oven Repair (including Ranges and Cooktops) 0 06-23-2009 08:30 AM
