Register | FAQ's | New Posts | Today's Posts | Extras |
» F1-8 Code, disconnected touchpad ribbon, then F1-7 error code |
![]() Model Number: JGS8850ADQ Brand: Jenn-Air Age: 5 - 10 years
![]() My oven shows the F1-8 error code which would indicate that the "control" must be replaced. Which control? The touchpad or the ERC (clock)? I read that that there is a way to determine which control should be replaced. First, disconnect the ribbon from the touchpad. Then, put the control panel back in place and plug in. If the F1 error code comes back, replace the ERC. If the F1 error code does not come back, replace the touch pad. Well, I did this and I got the F1-7 (not the F1-8) error code with the touch pad ribbon disconnected. I am assuming this indicates that I should replace the ERC. Does that sound right? Looking for some confirmation before I spend a couple hundred bucks. Thanks! Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Quote:
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Maytag SE1000 touchpad blinking no responce code-18 | Nina Parrish | Dryer Repair | 0 | 09-27-2013 09:50 PM |
ERROR CODE F6E5 Cancel key error | tammike | Oven Repair (including Ranges and Cooktops) | 8 | 08-06-2012 08:54 AM |
Duet error code FH and diagnostic code C03 | angelo78 | Washer Repair | 0 | 03-21-2012 08:12 AM |
LG Oven - F0 Code - Touchpad Problems | wbmilford | Oven Repair (including Ranges and Cooktops) | 0 | 02-09-2011 07:22 PM |
frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
