Discuss
Broiler always on but no bake element
 in
Recently the unit would beep, stop cooking and then flash “F1-1”- “Call for Service”. By turning offthe circuit breaker and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Broiler always on but no bake element
  #1 (permalink)
Old 09-28-2013, 04:56 PM
Junior Member
tardio is on a distinguished road
Default Broiler always on but no bake element
Model Number: JES8850AAW   Brand: Jenn-Air   Age: More than 10 years
Recently the unit would beep, stop cooking and then flash “F1-1”- “Call for Service”. By turning offthe circuit breaker and waiting a few minutes the stovetop and oven would work again
Today while preheating the oven there was a small “Pop”noise. and my wife thought she smelled a hint of an electrical burn with adefinite smell of food burning but there was nothing in the oven except theracks. My wife turned off the breakerand back on a few minutes later. She setbake to preheat to 400 degrees and it beeped when ready. She then put a roast in a pan in the oven forabout 15 minutes when she noticed there was cooking smoke present and the smellof the roast beginning to burn. The ovenbroiler element was on, the cause of the meat to burn, but the lower bakeelement was not on. At this point the beeping and the F1-1flashed. She turned the breaker off andreset it in 5 minutes but the bake element will not go on, only the broilerelement would go on.
The stove top works but the broiler element also turns on whenyou turn on the stove top. The bakeelement will not go on at all.
Related Models
Jenn-Air JES8850AAW RANGE- S/C S/I ELE
Jenn-Air JES8850ACB RANGE- S/C S/I ELE
Jenn-Air JES8850ACS RANGE- S/C S/I ELE
Jenn-Air JES8850ACW RANGE- S/C S/I ELE
Jenn-Air JES8850BAB RANGE- S/C S/I ELE
Maytag JES8850BAB19 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES8850BAF RANGE- S/C S/I ELE
Maytag JES8850BAF19 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES8850BAQ RANGE- S/C S/I ELE
Jenn-Air JES8850BAS RANGE- S/C S/I ELE
Maytag JES8850BAS20 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES8850BCB RANGE- S/C S/I ELE
Maytag JES8850BCB20 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES8850BCS RANGE- S/C S/I ELE
Maytag JES8850BCS21 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES8850BCW RANGE- S/C S/I ELE
Maytag JES8850CAB00 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES8850CAB01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8850CAF00 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES8850CAF01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8850CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8850CAS01 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES8850CAS02 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8860CAB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8860CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8860CAW00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8860CCB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8860CCS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8860CCS01 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES8860CCS02 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8860CCW00 30" SLIDE-IN ELECTRIC RANGE
General Electric JES922T01 Counter top microwave
General Electric JES922T02 Counter top microwave
General Electric JES927TWH01 Counter top microwave
General Electric JES933BW01 Counter top microwave
General Electric JES933PN01 Counter top microwave
General Electric JES933PN02 SAMSUNG .9 MICROWAVE
General Electric JES933PN03 SAMSUNG .9 MICROWAVE
General Electric JES933WN01 Counter top microwave
General Electric JES933WN02 SAMSUNG .9 MICROWAVE
General Electric JES933WN03 SAMSUNG .9 MICROWAVE
General Electric JES933WW01 Counter top microwave
General Electric JES933WW02 Counter top microwave
General Electric JES934WY01 Counter top microwave
General Electric JES939WD001 Counter top microwave
General Electric JES939WD002 Counter top microwave
Jenn-Air JES9750AAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9750AAS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9750AAW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9750BAB RANGE- S/C S/I DDRAFT ELE
Maytag JES9750BAB17 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9750BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9750BAS18 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9750BAW RANGE- S/C S/I DDRAFT ELE
Maytag JES9750BAW17 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9750CAB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9750CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9750CAS01 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9750CAS02 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9750CAW00 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9800AAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800AAQ RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800AAS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800AAW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800ACB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800ACS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800ACW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800BAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800BAF RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9800BAS18 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAB17 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAF00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAF17 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAR00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAS01 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860AAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860AAS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860AAW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860ACB RANGE- S/C S/I ELE
Jenn-Air JES9860ACS RANGE- S/C S/I ELE
Jenn-Air JES9860ACW RANGE- S/C S/I ELE
Jenn-Air JES9860BAB RANGE- S/C S/I DDRAFT ELE
Maytag JES9860BAB18 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9860BAS19 SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860BAW RANGE- S/C S/I DDRAFT ELE
Maytag JES9860BAW18 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860BCB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860BCS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860BCW RANGE- S/C S/I DDRAFT ELE
Maytag JES9860CAB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CAS01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CAW00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCS01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCW00 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BAB RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BAB19 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BAF RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BAF18 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900BAF19 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BAS20 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BCB RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BCB20 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BCS RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BCS21 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BCW RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BCW20 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCS01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCW00 30" SLIDE-IN ELECTRIC RANGE
General Electric JET1050A1 Counter top microwave
General Electric JET1050Y4 Counter top microwave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Stove-broiler and bake element wont come on Debbie711 Oven Repair (including Ranges and Cooktops) 4 10-16-2012 08:18 AM
broiler and bake element not working rangerepair Oven Repair (including Ranges and Cooktops) 11 02-02-2012 03:26 PM
Broiler element comes on instead of Bake mstriker250 Oven Repair (including Ranges and Cooktops) 3 01-26-2011 05:32 PM
Bake element doesn't heat, but broiler heats slightly pgf Oven Repair (including Ranges and Cooktops) 1 04-19-2009 03:30 PM
Broiler Element vs. Bake Element sblank3 Oven Repair (including Ranges and Cooktops) 6 02-18-2009 07:16 AM
