Discuss
Kenmore power burner on glasstop is half working
 in
The front left burner on my kenmore glasstop is only half working. There is only a switch for the heat,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore power burner on glasstop is half working
  #1 (permalink)
Old 09-23-2013, 03:13 PM
Junior Member
igneous is on a distinguished road
Default Kenmore power burner on glasstop is half working
Brand: Kenmore   Age: 1 - 5 years
The front left burner on my kenmore glasstop is only half working. There is only a switch for the heat, and then a button for simmer select. When I turn it on high the outer 50% turns read, but the middle part is clearly not turning on. I haven't pulled anything apart yet, just trying to figure out if its possible a simple fix.
  #2 (permalink)
Old 09-24-2013, 08:27 PM
Junior Member
Default
this is what it looks like on high, before the entire middle part would be red, now you can clearly see part of the burner isn't on
  #3 (permalink)
Old 09-25-2013, 03:45 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
It could be the element itself or the infinite switch.
A model number would be helpful.
Find your model number - AppliancePartsPros.com
I may then be able to find a wiring diagram that could make it easier for you to measure the heating coils in the element.
If they check out OK for continuity the I would replace the infinit switch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore SxS, Frig. half not working 1TechDad Refrigerator & Freezer Repair 0 04-22-2012 08:29 PM
Whirlpool glasstop range has a burner that does not work clevelandlyt Oven Repair (including Ranges and Cooktops) 1 08-28-2011 04:22 AM
Half a burner not working thompson.5 Oven Repair (including Ranges and Cooktops) 1 06-29-2011 04:46 AM
Half a burner cjkim1030 Oven Repair (including Ranges and Cooktops) 1 04-24-2011 05:06 AM
Instructions to replace glasstop burner element Don 97467 Oven Repair (including Ranges and Cooktops) 0 01-31-2010 12:51 PM
