Discuss
free standing gas range
 in
I have a frigidaire model FFGF3023LWB free standing gas range with electronic ignition that went out of warranty Aug.28 2013.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » free standing gas range
  #1 (permalink)
Old 09-23-2013, 02:33 PM
Junior Member
klif57 is on a distinguished road
Default free standing gas range
Model Number: FFGF3023LWB   Brand: Frigidaire   Age: 1 - 5 years
I have a frigidaire model FFGF3023LWB free standing gas range with electronic ignition that went out of warranty Aug.28 2013. The left front burner has no ignition spark. As the remaining burners light with their individual ignition spark I believe the problem is the Spark Electrode Ignition Harness. I am trying to find out how I access this device. Frigidaire tells me that the cooktop does not lift up and to call a technician. The burner bases are not the lift and pull type shown in many of the repair videos.Each burner has two hex head bolts that can be readily seen and accessed from the top. These bolts are white metal possibly zinc and I can anticipate the heads breaking off as soon as a constant pressure is applied after 3 years of use. In addition all 8 bolts would have to be removed in order to inspect or repair any burner. Is a design this bad. Can anyone contribute the correct access for a repair. Thank You
Related Models
Frigidaire FFGF3023LWB GAS RANGE
Frigidaire FFGF3023LWC GAS RANGE
Frigidaire FFGF3027LBA GAS RANGE
Frigidaire FFGF3027LBB GAS RANGE
Frigidaire FFGF3027LSA GAS RANGE
Frigidaire FFGF3027LSB GAS RANGE
Frigidaire FFGF3027LSC GAS RANGE
Frigidaire FFGF3027LWA GAS RANGE
Frigidaire FFGF3027LWB GAS RANGE
Frigidaire FFGF3047LSA GAS RANGE
Frigidaire FFGF3047LSB GAS RANGE
Frigidaire FFGF3047LSC GAS RANGE
Frigidaire FFGF3047LSD GAS RANGE
Frigidaire FFGF3047LSE GAS RANGE
Frigidaire FFGF3049LSA GAS RANGE
Frigidaire FFGF3049LSB GAS RANGE
Frigidaire FFGF3049LSC GAS RANGE
Frigidaire FFGF3049LSD GAS RANGE
Frigidaire FFGF3049LSE GAS RANGE
Frigidaire FFGF3051LSA GAS RANGE
Frigidaire FFGF3051LSB GAS RANGE
Frigidaire FFGF3051LSC GAS RANGE
Frigidaire FFGF3051LSD GAS RANGE
Frigidaire FFGF3051LSE GAS RANGE
Frigidaire FFGF3051LSF GAS RANGE
Frigidaire FFGF3053LSA GAS RANGE
Frigidaire FFGF3053LSB GAS RANGE
Frigidaire FFGF3053LSC GAS RANGE
Frigidaire FFGF3053LSD GAS RANGE
Frigidaire FFGF3053LSE GAS RANGE
Frigidaire FFGF3053LSF GAS RANGE
Frigidaire FFGS3025LBA GAS RANGE
Frigidaire FFGS3025LBB GAS RANGE
Frigidaire FFGS3025LBC GAS RANGE
Frigidaire FFGS3025LBD GAS RANGE
Frigidaire FFGS3025LSA GAS RANGE
Frigidaire FFGS3025LSB GAS RANGE
Frigidaire FFGS3025LSC GAS RANGE
Frigidaire FFGS3025LSD GAS RANGE
Frigidaire FFGS3025LWA GAS RANGE
Frigidaire FFGS3025LWB GAS RANGE
Frigidaire FFGS3025LWC GAS RANGE
Frigidaire FFGS3025LWD GAS RANGE
Frigidaire FFH1767GW0 FREEZER
Frigidaire FFH1767GW1 FREEZER
Frigidaire FFH1767GW2 FREEZER
Frigidaire FFH1767GWZ FREEZER
Frigidaire FFH17F7HWA FREEZER
Frigidaire FFH17F7HWC FREEZER
Frigidaire FFH17F7HWD FREEZER
Frigidaire FFH17F7HWF FREEZER
Frigidaire FFH17F7HWG FREEZER
Frigidaire FFH17F7HWH FREEZER
Frigidaire FFH17FC7CW0 Frigidaire/freezer
Frigidaire FFHI1817LB0 REFRIGERATOR
Frigidaire FFHI1817LB1 REFRIGERATOR
Frigidaire FFHI1817LB2 REFRIGERATOR
Frigidaire FFHI1817LB3 REFRIGERATOR
Frigidaire FFHI1817LB4 REFRIGERATOR
Frigidaire FFHI1817LS0 REFRIGERATOR
Frigidaire FFHI1817LS1 REFRIGERATOR
Frigidaire FFHI1817LS2 REFRIGERATOR
Frigidaire FFHI1817LS3 REFRIGERATOR
Frigidaire FFHI1817LW0 REFRIGERATOR
Frigidaire FFHI1817LW1 REFRIGERATOR
Frigidaire FFHI1817LW2 REFRIGERATOR
Frigidaire FFHI1817LW3 REFRIGERATOR
Frigidaire FFHI1817LW4 REFRIGERATOR
Frigidaire FFHI1826LB0 REFRIGERATOR
Frigidaire FFHI1826LB1 REFRIGERATOR
Frigidaire FFHI1826LB2 FRIGIDAIRE/REFRIGERATOR
Frigidaire FFHI1826LB3 REFRIGERATOR
Frigidaire FFHI1826LB4 REFRIGERATOR
Frigidaire FFHI1826LK0 REFRIGERATOR
Frigidaire FFHI1826LK1 REFRIGERATOR
Frigidaire FFHI1826LK2 REFRIGERATOR
Frigidaire FFHI1826LK3 REFRIGERATOR
Frigidaire FFHI1826LK4 REFRIGERATOR
Frigidaire FFHI1826LS0 REFRIGERATOR
Frigidaire FFHI1826LS1 REFRIGERATOR
Frigidaire FFHI1826LS2 FRIGIDAIRE/REFRIGERATOR
Frigidaire FFHI1826LS3 REFRIGERATOR
Frigidaire FFHI1826LS4 REFRIGERATOR
Frigidaire FFHI1826LW0 REFRIGERATOR
Frigidaire FFHI1826LW1 REFRIGERATOR
Frigidaire FFHI1826LW2 FRIGIDAIRE/REFRIGERATOR
Frigidaire FFHI1826LW3 REFRIGERATOR
Frigidaire FFHI1826LW4 REFRIGERATOR
Frigidaire FFHI2117LB0 REFRIGERATOR
Frigidaire FFHI2117LB2 REFRIGERATOR
Frigidaire FFHI2117LS0 REFRIGERATOR
Frigidaire FFHI2117LS2 REFRIGERATOR
Frigidaire FFHI2117LW0 REFRIGERATOR
Frigidaire FFHI2117LW1 REFRIGERATOR
Frigidaire FFHI2126LB1 REFRIGERATOR
Frigidaire FFHI2126LK1 REFRIGERATOR
Frigidaire FFHI2126LS1 REFRIGERATOR
Frigidaire FFHI2126LW1 REFRIGERATOR
Frigidaire FFHS2311LB0 REFRIGERATOR
Frigidaire FFHS2311LB1 REFRIGERATOR
Frigidaire FFHS2311LB2 REFRIGERATOR
Frigidaire FFHS2311LB3 REFRIGERATOR
Frigidaire FFHS2311LQ0 REFRIGERATOR
Frigidaire FFHS2311LQ2 REFRIGERATOR
Frigidaire FFHS2311LQ3 REFRIGERATOR
Frigidaire FFHS2311LW0 REFRIGERATOR
Frigidaire FFHS2311LW1 REFRIGERATOR
Frigidaire FFHS2311LW2 REFRIGERATOR
Frigidaire FFHS2311LW3 REFRIGERATOR
Frigidaire FFHS2313LE0 REFRIGERATOR
Frigidaire FFHS2313LE1 REFRIGERATOR
Frigidaire FFHS2313LE3 REFRIGERATOR
Frigidaire FFHS2313LE4 REFRIGERATOR
Frigidaire FFHS2313LM0 REFRIGERATOR
Frigidaire FFHS2313LM1 REFRIGERATOR
Frigidaire FFHS2313LM3 REFRIGERATOR
Frigidaire FFHS2313LM4 REFRIGERATOR
Frigidaire FFHS2313LP0 REFRIGERATOR
Frigidaire FFHS2313LP3 REFRIGERATOR
Frigidaire FFHS2313LP4 REFRIGERATOR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
free standing range Mike Olexa Oven Repair (including Ranges and Cooktops) 1 11-30-2012 05:13 PM
Free standing Gas Range ATAMER Oven Repair (including Ranges and Cooktops) 0 12-09-2011 04:13 PM
Radiant Electric Free Standing Range ablalock Oven Repair (including Ranges and Cooktops) 2 03-05-2010 10:21 AM
Thermador Free Standing Range SpaceAce Oven Repair (including Ranges and Cooktops) 1 08-14-2007 01:28 AM
Gibson free standing gas range Virginia Jones Oven Repair (including Ranges and Cooktops) 3 08-13-2007 11:36 PM
