Discuss
Jenn-Air Oven Door moves hard and jerky
 in
Tonight I opened the oven door and all seemed fine until I tried to close it. it stopped at the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Oven Door moves hard and jerky
  #1 (permalink)
Old 09-22-2013, 10:57 PM
Junior Member
pcostigan is on a distinguished road
Default Jenn-Air Oven Door moves hard and jerky
Model Number: SVD48600W   Brand: Jenn-Air   Age: More than 10 years
Tonight I opened the oven door and all seemed fine until I tried to close it. it stopped at the broil stop position. I pushed harder a fwe times then it finally closed, but with an odd feel and sounds. The door does appear to close all the way.
I spent a couple hours searching the internet, much of that on THIS web site. I downloaded the User and Installation manuals from www.JennAir.com so I could let the computer search for keywords such as door, hinge, etc. but did not find anything useful, not even instructions for how to remove the door (no hinge latches).
Does this sound like a hinge or receptacle problem? or something else? I'd really rather not take the door apart and/or order parts on a wild guess.
We purchased the range brand new in 1999 so it's 14 years old. The only other problme we had resultyed in the circuit board for the control panel being replaced under warrantee.
Related Models
Jenn-Air SVD48600W RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600WC RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310S RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310S-C RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SG RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SK RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SR RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SU RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVE47100B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47500B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47500W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600W RANGE- S/C S/I DDRAFT ELE
Whirlpool SVF12FRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW01 VERTICAL FREEZER
Whirlpool SVF15NRHW02 FREEZER
Whirlpool SVF15NRJW00 FREEZER
Whirlpool SVF20NRKQ00 FREEZER
Amana SW22H REF - SXS/I&W
Amana SW22MBG REF - SXS/I&W
Amana SW22MBL REF - SXS/I&W
Amana SW22MBW REF - SXS/I&W
Amana SW25H REF - SXS/I&W
Amana SWDT22H REF - SXS/I&W
Amana SWDT25H REF - SXS/I&W
Amana SWP25H REF - SXS/I&W
Amana SWPD25H REF - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1233HQ0 WASHER
White Westinghouse SWS1233HQ1 WASHER
White Westinghouse SWS1233HS0 WASHER
White Westinghouse SWS1233HS1 WASHER
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1339HQ0 WASHER
White Westinghouse SWS1339HQ1 WASHER
White Westinghouse SWS1339HS0 WASHER
White Westinghouse SWS1339HS1 WASHER
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS1649HQ0 WASHER
White Westinghouse SWS1649HQ1 WASHER
White Westinghouse SWS1649HS0 WASHER
White Westinghouse SWS1649HS1 WASHER
White Westinghouse SWS833HQ0 WASHER
White Westinghouse SWS833HQ1 WASHER
White Westinghouse SWS833HS0 WASHER
White Westinghouse SWS833HS1 WASHER
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWSG1031HQ0 LAUNDRY CENTER
White Westinghouse SWSG1031HQ2 LAUNDRY CENTER
White Westinghouse SWSG1031HQ4 LAUNDRY CENTER
White Westinghouse SWSG1031HS0 LAUNDRY CENTER
White Westinghouse SWSG1031HS1 LAUNDRY CENTER
White Westinghouse SWSG1031HS2 LAUNDRY CENTER
White Westinghouse SWSG1031HS4 LAUNDRY CENTER
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
White Westinghouse SWX703CQ0 White Westinghouse/washer
White Westinghouse SWX703CQ1 White Westinghouse/washer
White Westinghouse SWX703CS0 White Westinghouse/washer
White Westinghouse SWX703CS1 White Westinghouse/washer
White Westinghouse SWX703HQ0 WASHER
White Westinghouse SWX703HQ1 WASHER
White Westinghouse SWX703HS0 WASHER
White Westinghouse SWX703HS1 WASHER
White Westinghouse SWXG831DQ0 White Westinghouse/laundry Center
White Westinghouse SWXG831DQ1 White Westinghouse/laundry Center
White Westinghouse SWXG831DS0 White Westinghouse/laundry Center
White Westinghouse SWXG831DS1 White Westinghouse/laundry Center
White Westinghouse SWXG831HQ1 LAUNDRY CENTER
White Westinghouse SWXG831HQ2 LAUNDRY CENTER
White Westinghouse SWXG831HQ4 LAUNDRY CENTER
White Westinghouse SWXG831HS0 LAUNDRY CENTER
White Westinghouse SWXG831HS1 LAUNDRY CENTER
White Westinghouse SWXG831HS2 LAUNDRY CENTER
White Westinghouse SWXG831HS4 LAUNDRY CENTER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air oven door will not close embdenb Oven Repair (including Ranges and Cooktops) 7 02-18-2017 07:24 PM
Jenn Aire Micro/Oven combo, oven door does not shut tight dsazama Oven Repair (including Ranges and Cooktops) 6 07-25-2015 10:37 PM
Jenn Air oven door does not close all the way Meyekal Oven Repair (including Ranges and Cooktops) 3 10-06-2011 03:11 AM
Jenn Air Oven Door Handle has come off Louise Galvin Oven Repair (including Ranges and Cooktops) 0 03-15-2010 10:50 AM
Gas Stove Smells Like A Little Gas Inside Then I Turn It On The Oven Door Moves BOBBY ZEE Oven Repair (including Ranges and Cooktops) 0 01-19-2010 06:37 PM
