MRubin
#1 Posted : Friday, September 20, 2013 10:17:10 AM(UTC)
MRubin
Top works and control board works. Both elements will not turn on to either a bake or broil command. Elements look good. Was thinking sensor, but didn't want to buy one before checking here.
#2 Posted : Saturday, September 21, 2013 3:06:31 AM(UTC)
Parts for Maytag MES5775BAB Range - AppliancePartsPros.com
If the unit shows that the oven is ready then it could be the oven sensor.
It should measure about 1,100 ohms at room temperature.
If the oven stays in pre-heat then the hi-limit thermostat (item 6 in the Body Parts section) may be open.
File Attachment(s):
MES5775.pdf (370kb) downloaded 4 time(s).
MRubin
#3 Posted : Saturday, September 21, 2013 5:46:05 AM(UTC)
MRubin
Thank you for your response. Where is the thermostat located. I see it in a separate box on that schematic. Wondering how to access that.
Ohms are correct on the sensor. So that is most likely the culprit. Oven wouldn't move off of 100 before either.
#4 Posted : Saturday, September 21, 2013 6:25:56 AM(UTC)
Looks like it is on the top right hand side of the oven compartment
Hi-Limit Thermostat
1. Remove maintop assembly, see "Maintop Assembly"
procedure.
2. Remove screws securing hi-limit thermostat to oven
chassis.
3. Reverse procedure to reinstall hi-limit thermostat.
Maintop Assembly
1. Remove power from unit.
2. Remove range from installation position, see
“Removing and Replacing Range” procedure.
3. Remove coil elements from installation position
(select models).
4. Open oven door and remove screws securing
maintop to oven chassis, located on the bottom of
control panel and along the outside edges of the
maintop.
5. Label and disconnect wiring to ribbon elements
(select models).
6. Gently remove ceran top (select models) and place in
safe area to prevent damage to top.
7. Remove porcelain maintop (select models).
8. Reverse procedure to reinstall maintop assembly.
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/4/2023 2:39:31 PM(UTC)
Dacor oven, upper oven not working (Oven Repair (including Ranges and Cooktops))
by notyepcars 11/26/2022 8:40:21 AM(UTC)
oven not working, gives me a code F3 (Oven Repair (including Ranges and Cooktops))
by cj9113 10/16/2021 7:56:35 AM(UTC)
GE PROFILE PGB995DET1WW Top oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 9/6/2021 9:36:45 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 6/30/2020 5:07:14 AM(UTC)
whirlpool WOD93EC0AS double oven bottom oven not working (Oven Repair (including Ranges and Cooktops))
by Chemsal 3/18/2020 3:28:11 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
Oven On light stays lit - Oven not working properly (Oven Repair (including Ranges and Cooktops))
by Lometir 3/20/2019 7:54:34 AM(UTC)
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 9/25/2018 1:00:51 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 1/1/2017 7:20:12 AM(UTC)
