Discuss
Older Gas Oven not heating up enough
 in
I have an all in one piece Tappan Gas Double Oven with Gas range circa early 80s. The bottom oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Older Gas Oven not heating up enough
  #1 (permalink)
Old 02-10-2008, 03:56 PM
Meg70 Meg70 is offline
Junior Member
Meg70 is on a distinguished road
Cool Older Gas Oven not heating up enough
Model Number: unknown   Brand: Tappan   Age: More than 10 years
I have an all in one piece Tappan Gas Double Oven with Gas range circa early 80s. The bottom oven does not seem to get hot enough. The top oven (small - 1 rack) works okay, but runs a bit high and heats a bit unevenly though. The gas range works fine.
Ideally, I don't want to replace until I am ready to redo the kitchen and know what type of oven & range along with layout I want. Is there anything I can do to fix the bottom oven that does not require a significant investment?
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-11-2008, 02:13 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide the most accurate advise I need the complete model number of the range. You can find it under the top stove panel.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas oven not heating up like it should fillhardfarm Oven Repair (including Ranges and Cooktops) 1 01-29-2008 07:06 PM
Replacing older GE oven gasket cleo59 Oven Repair (including Ranges and Cooktops) 3 01-14-2008 07:06 PM
GE Wall Double Oven Top Oven Not Heating ryoung Oven Repair (including Ranges and Cooktops) 0 01-10-2008 09:02 PM
Older Kenmore washer appears "dead"! Cappy Washer Repair 0 10-27-2007 08:18 PM
Timer clock module for older Whirlpool oven webber123456 Oven Repair (including Ranges and Cooktops) 1 07-22-2007 11:16 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
