Discuss
Kenmore Gas range hase low flame on all burners and in oven
 in
had low flame on all burners and in oven , checked supply it was good and replace the supply valve
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Gas range hase low flame on all burners and in oven
  #1 (permalink)
Old 09-11-2013, 01:37 PM
Junior Member
eddyr123 is on a distinguished road
Smile Kenmore Gas range hase low flame on all burners and in oven
Model Number: 36275271692   Brand: Kenmore   Age: 5 - 10 years
had low flame on all burners and in oven , checked supply it was good and replace the supply valve and still no change. I cleaned all orifices and am now at a loss as to what could be causing it.
Any suggestions?
Related Models
Kenmore 36275271692 GAS RANGE
Kenmore 36275275690 GAS RANGE
Kenmore 36275275691 GAS RANGE
Kenmore 36275275692 GAS RANGE
Kenmore 36275276690 GAS RANGE
Kenmore 36275276691 GAS RANGE
Kenmore 36275276692 GAS RANGE
Kenmore 36275278690 GAS RANGE
Kenmore 36275278691 GAS RANGE
Kenmore 36275278692 GAS RANGE
Kenmore 36275281790 GAS, RANGE
Kenmore 36275291790 GAS RANGE
Kenmore 36275295790 GAS RANGE
Kenmore 36275296790 GAS RANGE
Kenmore 36275298790 GAS RANGE
Kenmore 36275320100 GAS RANGE
Kenmore 36275320101 GAS RANGE
Kenmore 36275320102 GAS RANGE
Kenmore 36275321000 GAS RANGE
Kenmore 36275321001 GAS RANGE
Kenmore 36275321002 GAS RANGE
Kenmore 36275321003 GAS RANGE
Kenmore 36275321004 GAS RANGE
Kenmore 36275322000 GAS RANGE
Kenmore 36275322001 GAS RANGE
Kenmore 36275322002 GAS RANGE
Kenmore 36275322003 GAS RANGE
Kenmore 36275322004 GAS RANGE
Kenmore 36275324100 GAS RANGE
Kenmore 36275324101 GAS RANGE
Kenmore 36275324102 GAS RANGE
Kenmore 36275327000 GAS RANGE
Kenmore 36275327001 GAS RANGE
Kenmore 36275328000 GAS RANGE
Kenmore 36275328001 GAS RANGE
Kenmore 36275329100 GAS RANGE
Kenmore 36275329101 GAS RANGE
Kenmore 36275329102 GAS RANGE
Kenmore 3627535190 GAS RANGE
Kenmore 3627535890 GAS RANGE
Kenmore 3627536190 GAS RANGE
Kenmore 3627536191 GAS RANGE
Kenmore 3627536192 GAS RANGE
Kenmore 3627536890 GAS RANGE
Kenmore 3627536891 GAS RANGE
Kenmore 3627536892 GAS RANGE
Kenmore 36275371690 GAS RANGE
Kenmore 36275375690 GAS RANGE
Kenmore 36275376690 GAS RANGE
Kenmore 36275378690 GAS RANGE
Kenmore 36275381890 GAS RANGE
Kenmore 36275381891 GAS RANGE
Kenmore 36275381892 GAS RANGE
Kenmore 36275388890 GAS RANGE
Kenmore 36275388891 GAS RANGE
Kenmore 36275388892 GAS RANGE
Kenmore 36275471690 GAS RANGE
Kenmore 36275471691 GAS RANGE
Kenmore 36275478690 GAS RANGE
Kenmore 36275478691 GAS RANGE
Kenmore 36275481890 GAS RANGE
Kenmore 36275481891 GAS RANGE
Kenmore 36275488890 GAS RANGE
Kenmore 36275488891 GAS RANGE
Kenmore 36275491990 GAS RANGE
Kenmore 36275491991 GAS RANGE
Kenmore 36275491992 GAS RANGE
Kenmore 36275492000 GAS RANGE
Kenmore 36275492001 GAS RANGE
Kenmore 36275497000 GAS RANGE
Kenmore 36275497001 GAS RANGE
Kenmore 36275498990 GAS RANGE
Kenmore 36275498991 GAS RANGE
Kenmore 36275498992 GAS RANGE
Kenmore 36275501990 GAS RANGE
Kenmore 36275501991 GAS RANGE
Kenmore 36275502000 GAS RANGE
Kenmore 36275502001 GAS RANGE
Kenmore 36275507000 GAS RANGE
Kenmore 36275507001 GAS RANGE
Kenmore 36275508990 GAS RANGE
Kenmore 36275508991 GAS RANGE
Kenmore 36275521000 GAS RANGE
Kenmore 36275521001 GAS RANGE
Kenmore 36275528000 GAS RANGE
Kenmore 36275528001 GAS RANGE
Kenmore 3627555190 GAS RANGE
Kenmore 3627555590 GAS RANGE
Kenmore 3627555890 GAS RANGE
Kenmore 3627555990 GAS RANGE
Kenmore 3627556190 30" FREESTANDING GAS RANGE
Kenmore 3627556191 GAS RANGE
Kenmore 3627556590 30" FREESTANDING GAS RANGE
Kenmore 3627556591 GAS RANGE
Kenmore 3627556890 30" FREESTANDING GAS RANGE
Kenmore 3627556891 GAS RANGE
Kenmore 3627556892 GAS RANGE
Kenmore 3627556991 GAS RANGE
Kenmore 3627556992 GAS RANGE
Kenmore 36275571690 GAS RANGE
Kenmore 36275571691 GAS RANGE
Kenmore 36275575690 GAS RANGE
Kenmore 36275575691 GAS RANGE
Kenmore 36275576690 GAS RANGE
Kenmore 36275576691 GAS RANGE
Kenmore 36275578690 GAS RANGE
Kenmore 36275578691 GAS RANGE
Kenmore 36275581890 GAS RANGE
Kenmore 36275581891 GAS RANGE
Kenmore 36275581892 Free Standing, Gas
Kenmore 36275585890 Free Standing, Gas
Kenmore 36275585891 GAS RANGE
Kenmore 36275585892 GAS RANGE
Kenmore 36275586890 Free Standing, Gas
Kenmore 36275586891 GAS RANGE
Kenmore 36275586892 GAS RANGE
Kenmore 36275588890 GAS RANGE
Kenmore 36275588891 GAS RANGE
Kenmore 36275588892 Free Standing, Gas
Kenmore 36275620300 GAS RANGE
  #2 (permalink)
Old 09-11-2013, 06:23 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Sounds like you have a bad regulator or low gas pressure going to unit....
  #3 (permalink)
Old 09-11-2013, 06:48 PM
Junior Member
Smile
Quote:
Gas company checked pressure at supply line and it was good, I replaced the Pressure valve PART NUMBER: WB19K28 and no change. Not sure, but i believe that is the pressure regulator valvle I replaced.
Thanks though any other thoughts?
  #4 (permalink)
Old 09-11-2013, 07:25 PM
Senior Member
Default
have you recently changed this unit from propane or to propane at all?
  #5 (permalink)
Old 09-11-2013, 07:35 PM
Junior Member
Smile
Sorry did not mention that it is propane and has been since new
  #6 (permalink)
Old 09-11-2013, 07:39 PM
Senior Member
Default
And you have the new regulator put in the LP position? There should be a switch somewhere on it......also did you change the orfice out of the regulator and put the LP orfice in the new regulator you installed?
  #7 (permalink)
Old 09-11-2013, 07:57 PM
Junior Member
Smile
Didn't think about that, is it the brass plug/nut on the side of the regulator? I changed the orifice to LP and no change. I could not find a switch, but the stove worked fine until a few weeks ago. I even changed the safety valve today just to be sure. and replaced the supply line to.
It lights just fine then the flame goes very small. This is the case on all four burner and the oven.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Gas range hase low flame on all burners and in oven eddyr123 Oven Repair (including Ranges and Cooktops) 0 09-11-2013 01:34 PM
flame on my burners and oven ksmith29530 Oven Repair (including Ranges and Cooktops) 0 03-10-2012 10:43 AM
Maytag Range burners huge flame from one spot Kahn Oven Repair (including Ranges and Cooktops) 0 03-14-2009 09:16 AM
sealed cooktop burners low flame large burners only heavy chevy Oven Repair (including Ranges and Cooktops) 3 12-22-2007 08:37 AM
sealed cooktop burners low flame large burners only heavy chevy Oven Repair (including Ranges and Cooktops) 0 12-21-2007 05:36 PM
