Discuss
Frigidaire Oven F3 code
 in
I have changed the Probe out twice. F3 continues to come up after the oven is used a time or
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Oven F3 code
  #1 (permalink)
Old 09-07-2013, 07:31 AM
Junior Member
gdeanrussell is on a distinguished road
Default Frigidaire Oven F3 code
Model Number: Model PLEB30S8ACA   Brand: Frigidaire   Age: 5 - 10 years
I have changed the Probe out twice. F3 continues to come up after the oven is used a time or two after a new probe is installed. Was thinking the probes were ohming 0. Changed to a Fluke meter they are not. Failed probe and new probe out of the box both have a resistance of 1100. What do I do now?
Related Models
Whirlpool MODEL_PBK0190
Magic Chef MODW1A MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MODW1V MWAVE- MOUNTED OVER RANGE/WO
Amana MP1.A COMMERCIAL MICROWAVES
Amana MP1.B COMMERCIAL MICROWAVES
Amana MPD218-02 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire MPF200PBDA Frg(v2) / Gas Range
Frigidaire MPF200PBWA Frg(v1) / Gas Range
Frigidaire MPF240GSA GAS RANGE
Frigidaire MPF300BPDA Gib(v9) / Gas Range
Frigidaire MPF300PBDA Frg(v1) / Gas Range
Frigidaire MPF300PBDB Wwh(v1) / Gas Range
Frigidaire MPF300PBDC Frg(v1) / Gas Range
Frigidaire MPF300PBDD Frg(v1) / Gas Range
Frigidaire MPF300PBDE Frg(v1) / Gas Range
Frigidaire MPF300PBDF Frg(v1) / Gas Range
Frigidaire MPF300PBWA Frg(v2) / Gas Range
Frigidaire MPF300PBWB Wwh(v2) / Gas Range
Frigidaire MPF300PBWC Frg(v2) / Gas Range
Frigidaire MPF300PBWD Frg(v2) / Gas Range
Frigidaire MPF300PBWE Frg(v2) / Gas Range
Frigidaire MPF300PBWF Frg(v2) / Gas Range
Frigidaire MPF300PXWA Frg(v0) / Gas Range
Frigidaire MPF300PXWB Frg(v3) / Gas Range
Frigidaire MPF300PXWC Frg(v0) / Gas Range
Frigidaire MPF300PXWG Universal/gas Range
Frigidaire MPF300PXWH Universal/gas Range
Frigidaire MPF300PXWJ Universal/gas Range
Frigidaire MPF303PGDA Frg(v3) / Gas Range
Frigidaire MPF303PGDD Frg(v5) / Gas Range
Frigidaire MPF303PGDF Universal/gas Range
Frigidaire MPF303PGDG Universal/gas Range
Frigidaire MPF303PGDH Universal/gas Range
Frigidaire MPF303PGWA Frg(v4) / Gas Range
Frigidaire MPF303PGWC Frg(v6) / Gas Range
Frigidaire MPF303PGWD Frg(v7) / Gas Range
Frigidaire MPF303PGWF Universal/gas Range
Frigidaire MPF303PGWG Universal/gas Range
Frigidaire MPF303PGWH Universal/gas Range
Frigidaire MPF311PCDA Tap(v1) / Gas Range
Frigidaire MPF311PCWA Tap(v2) / Gas Range
Frigidaire MPF311PCWB Frg(v0) / Gas Range
Frigidaire MPF311PCWC Frg(v1) / Gas Range
Frigidaire MPF311PCWD Frg(v0) / Gas Range
Frigidaire MPF311PGWA Frg(v3) / Gas Range
Frigidaire MPF311PGWC Frg(v3) / Gas Range
Frigidaire MPF311PGWD Frg(v3) / Gas Range
Frigidaire MPF311PGWE Universal/gas Range
Frigidaire MPF311SBDA Frg(v3) / Gas Range
Frigidaire MPF311SBDB Frg(v1) / Gas Range
Frigidaire MPF311SBDC Frg(v2) / Gas Range
Frigidaire MPF311SBDD Frg(v1) / Gas Range
Frigidaire MPF311SBWA Frg(v4) / Gas Range
Frigidaire MPF311SBWB Frg(v2) / Gas Range
Frigidaire MPF311SBWC Frg(v3) / Gas Range
Frigidaire MPF311SBWD Frg(v2) / Gas Range
Frigidaire MPF311SGDA Frg(v4) / Gas Range
Frigidaire MPF311SGDC Frg(v4) / Gas Range
Frigidaire MPF311SGDD Frg(v4) / Gas Range
Frigidaire MPF311SGDE Universal/gas Range
Frigidaire MPF311SGWA Frg(v5) / Gas Range
Frigidaire MPF311SGWC Frg(v5) / Gas Range
Frigidaire MPF311SGWD Frg(v5) / Gas Range
Frigidaire MPF311SGWE Universal/gas Range
Frigidaire MPF500PBDA Frg(v4) / Gas Range
Frigidaire MPF500PBDB Frg(v1) / Gas Range
Frigidaire MPF500PBWA Frg(v3) / Gas Range
Frigidaire MPF500PBWB Frg(v2) / Gas Range
Amana MPP227 MWAVE- CNTRTP / STAND ALONE
Amana MPP228 MWAVE- CNTRTP / STAND ALONE
Amana MPP228100L MWAVE - FAMILY SIZE (60 HZ)
Amana MPR215 MWAVE- CNTRTP / STAND ALONE
Amana MPR21510 MWAVE- MOUNTED OVER RANGE/WO
Amana MPR217 MWAVE- CNTRTP / STAND ALONE
Amana MPR219 MWAVE- CNTRTP / STAND ALONE
Amana MPS218-10 RANGE- S/C S/I DDRAFT GAS
Amana MPS218-10 MWAVE- CNTRTP / STAND ALONE
Amana MPS219-10 RANGE- S/C S/I DDRAFT GAS
Amana MPS219-10 MWAVE- CNTRTP / STAND ALONE
Amana MPS225-10 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS22510 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS229-10 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS22910 MWAVE - FAMILY SIZE (60 HZ)
Maytag MQC1557AEW FREEZER- VERTICAL
Maytag MQC1557BEW FREEZER- CHEST
Maytag MQC2257AEW FREEZER- CHEST
Maytag MQC2257BEW FREEZER- CHEST
Maytag MQU1554AEW FREEZER- VERTICAL
Maytag MQU1556AEW FREEZER- VERTICAL
Maytag MQU1654BEW FREEZER- VERTICAL
Maytag MQU1656BEW FREEZER- VERTICAL
Maytag MQU2056ARW FREEZER- VERTICAL
Maytag MQU2056BRW FREEZER- VERTICAL
Maytag MQU2056BRW03 VERTICAL FREEZER
Maytag MQU2057AEW FREEZER- VERTICAL
Maytag MQU2057BEW FREEZER- VERTICAL
Amana MR-1 RANGE- S/C S/I DDRAFT GAS
Amana MR-1W MWAVE - FAMILY SIZE (60 HZ)
Amana MR-2 RANGE- S/C S/I DDRAFT GAS
Amana MR-3 MWAVE - FAMILY SIZE (60 HZ)
 MR1031CWC MWAVE- CNTRTP / STAND ALONE
 MR1031UWC MWAVE- CNTRTP / STAND ALONE
 MR1031WB MWAVE- CNTRTP / STAND ALONE
 MR1032BB MWAVE- CNTRTP / STAND ALONE
 MR1032CBC MWAVE- CNTRTP / STAND ALONE
 MR1032UBC MWAVE- CNTRTP / STAND ALONE
 MR1033SB MWAVE- CNTRTP / STAND ALONE
 MR1034CBD MWAVE- CNTRTP / STAND ALONE
 MR1034CWD MWAVE- CNTRTP / STAND ALONE
 MR1034UBD MWAVE- CNTRTP / STAND ALONE
 MR1034UWD MWAVE- CNTRTP / STAND ALONE
 MR1351WB MWAVE- CNTRTP / STAND ALONE
  #2 (permalink)
Old 09-07-2013, 08:28 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire PLEB30S8ACA Wall Oven - AppliancePartsPros.com
May be just semantics but I looked up the F3 code and it says an "open sensor".
This would be infinite ohms not zero ohms.
What do I do now?
If the probe plugs into a harness and then that harness goes to the control board check that the harness pins are clean and properly crimped. You could check the sensor resistance at the control board. Use the meter in both polarities as electronics on the board may effect the reading.
The next check is a bit tricky. You have to get to the solder side of the control board. Looks like it un-clips from the plastic case and then has to be gently bent back. The bare wires at one end of the board are hard wired so that is the hinge side.
Now check the solder connections at the sensor plug for clod solder etc. Cold solder joints often have pin holes and/or are a duller silver color.
Gently wiggle the sensor plug while watching the solder side to see if the pins move in the solder.
Check that the circuit trails going to the plug do not have cracks.
A magnifying glas is useful when checking pins etc.
If all OK you probably need a new control board/timer.
Unfortunately it does not look like the control board is available but I would call them just to be sure.
there are companies out there that will fix obsolete boards just Google "appliance timer repair".
Yours may be a problem as if I understand your post correctly, the fault is intermittent so it may be hard for them to troubleshoot the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire oven error code F2 engleg Oven Repair (including Ranges and Cooktops) 0 08-22-2012 03:10 PM
Frigidaire oven f4 error code drudee Oven Repair (including Ranges and Cooktops) 0 11-27-2010 07:49 AM
Frigidaire Oven F-31 Code NESNAH24 Oven Repair (including Ranges and Cooktops) 0 08-28-2010 11:28 AM
Frigidaire Oven F1 Fault code bryankloos Oven Repair (including Ranges and Cooktops) 0 03-26-2010 06:25 PM
Frigidaire F5 Oven Code bdcurran Oven Repair (including Ranges and Cooktops) 0 05-11-2009 07:19 AM
