Discuss
Jenn-air top oven not working
 in
Hi, My top oven is not working, i've test it on BROIL without luck. I removed the back cover and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-air top oven not working
  #1 (permalink)
Old 09-07-2013, 06:37 AM
Ben Ben is offline
Junior Member
Ben is on a distinguished road
Default Jenn-air top oven not working
Model Number: sve47600wc   Brand: Jenn-Air   Age: More than 10 years
My top oven is not working, i've test it on BROIL without luck. I removed the back cover and test it using a voltmeter, i hear a click, then i see the Ohm go around 20-30 for a few sec then 0.000 and another "click".
The bottom oven is working, but it is hard to cook, it take longer than usual.
Also, check this picture, the top connector seem fried ? :
http://i.imgur.com/5IBh740.jpg
thanks!
Related Models
Jenn-Air SVE47600WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600W RANGE- S/C S/I DDRAFT ELE
Whirlpool SVF12FRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW01 VERTICAL FREEZER
Whirlpool SVF15NRHW02 FREEZER
Whirlpool SVF15NRJW00 FREEZER
Whirlpool SVF20NRKQ00 FREEZER
Amana SW22H REF - SXS/I&W
Amana SW22MBG REF - SXS/I&W
Amana SW22MBL REF - SXS/I&W
Amana SW22MBW REF - SXS/I&W
Amana SW25H REF - SXS/I&W
Amana SWDT22H REF - SXS/I&W
Amana SWDT25H REF - SXS/I&W
Amana SWP25H REF - SXS/I&W
Amana SWPD25H REF - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1233HQ0 WASHER
White Westinghouse SWS1233HQ1 WASHER
White Westinghouse SWS1233HS0 WASHER
White Westinghouse SWS1233HS1 WASHER
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1339HQ0 WASHER
White Westinghouse SWS1339HQ1 WASHER
White Westinghouse SWS1339HS0 WASHER
White Westinghouse SWS1339HS1 WASHER
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS1649HQ0 WASHER
White Westinghouse SWS1649HQ1 WASHER
White Westinghouse SWS1649HS0 WASHER
White Westinghouse SWS1649HS1 WASHER
White Westinghouse SWS833HQ0 WASHER
White Westinghouse SWS833HQ1 WASHER
White Westinghouse SWS833HS0 WASHER
White Westinghouse SWS833HS1 WASHER
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWSG1031HQ0 LAUNDRY CENTER
White Westinghouse SWSG1031HQ2 LAUNDRY CENTER
White Westinghouse SWSG1031HQ4 LAUNDRY CENTER
White Westinghouse SWSG1031HS0 LAUNDRY CENTER
White Westinghouse SWSG1031HS1 LAUNDRY CENTER
White Westinghouse SWSG1031HS2 LAUNDRY CENTER
White Westinghouse SWSG1031HS4 LAUNDRY CENTER
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
White Westinghouse SWX703CQ0 White Westinghouse/washer
White Westinghouse SWX703CQ1 White Westinghouse/washer
White Westinghouse SWX703CS0 White Westinghouse/washer
White Westinghouse SWX703CS1 White Westinghouse/washer
White Westinghouse SWX703HQ0 WASHER
White Westinghouse SWX703HQ1 WASHER
White Westinghouse SWX703HS0 WASHER
White Westinghouse SWX703HS1 WASHER
White Westinghouse SWXG831DQ0 White Westinghouse/laundry Center
White Westinghouse SWXG831DQ1 White Westinghouse/laundry Center
White Westinghouse SWXG831DS0 White Westinghouse/laundry Center
White Westinghouse SWXG831DS1 White Westinghouse/laundry Center
White Westinghouse SWXG831HQ1 LAUNDRY CENTER
White Westinghouse SWXG831HQ2 LAUNDRY CENTER
White Westinghouse SWXG831HQ4 LAUNDRY CENTER
White Westinghouse SWXG831HS0 LAUNDRY CENTER
White Westinghouse SWXG831HS1 LAUNDRY CENTER
White Westinghouse SWXG831HS2 LAUNDRY CENTER
White Westinghouse SWXG831HS4 LAUNDRY CENTER
Amana SX1021.000 COMMERCIAL MICROWAVES
Amana SX1051.000 COMMERCIAL MICROWAVES
Amana SX19ML REF - SXS/I&W
Amana SX19MW REF - SXS/I&W
Amana SX19NL REF - SXS/I&W
Amana SX19NW REF - SXS/I&W
Amana SX22H REF - SXS/I&W
Amana SX22J REF - SXS/I&W
Amana SX22J Ref - SXS/I&W
Amana SX22MG REF - SXS/I&W
Amana SX22ML REF - SXS/I&W
Amana SX22MW REF - SXS/I&W
Amana SX22NE REF - SXS/I&W
Amana SX22NL REF - SXS/I&W
  #2 (permalink)
Old 09-07-2013, 06:49 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Jenn-Air SVE47600WC Range - AppliancePartsPros.com
I only see one oven in the parts.
Do you mean oven or element (broil element and bake element)
__________________
  #3 (permalink)
Old 09-07-2013, 11:30 AM
Ben Ben is offline
Junior Member
Default
Quote:
Originally Posted by denman View Post
the broil element, so the number 6 in the parts (AP4567077).
So i can just change that for a new one? you sure that is the problem? What do you think of the connector on my picture?
  #4 (permalink)
Old 09-07-2013, 12:39 PM
Senior Expert
APP Volunteer
Default
OK so it is just the broil element that does not come on, correct?
Unplug the stove and one side of the element. Then measure it with a meter should be around 15 ohms.
If it is infinite ohms then it needs replacing.
Cannot really tell what is going on here though there does not appear to be any damage (overheating) of the wires. You will have to remove the tape and check the connection.
Note that the tape is not normal and has been installed by someone but I do not know why.
There are other things that can cause the broil element to not come on but the most common is a blown element.
__________________
  #5 (permalink)
Old 09-07-2013, 12:46 PM
Ben Ben is offline
Junior Member
Default
Okay thanks a lot for you time, i'll do that and order the part.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
jenn aire oven not working right meandmyrgc Oven Repair (including Ranges and Cooktops) 0 01-21-2011 05:22 AM
Jenn-Air Oven Display Not Working thatowl Oven Repair (including Ranges and Cooktops) 0 05-24-2010 02:04 PM
jenn-air oven not working cleanpad Oven Repair (including Ranges and Cooktops) 0 11-21-2009 07:25 PM
Jenn-AIR Oven LED light not working Patty Snow Oven Repair (including Ranges and Cooktops) 1 10-20-2008 02:33 PM
jenn air wall oven not working LesleyFarm Oven Repair (including Ranges and Cooktops) 0 08-01-2008 03:46 PM
