Discuss
Changing burner switch?
 in
how do I change a switch for the glass top large 8" burner??? I think I have my problem
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Changing burner switch?
  #1 (permalink)
Old 02-10-2008, 12:51 PM
hroliver1230 hroliver1230 is offline
Junior Member
hroliver1230 is on a distinguished road
Default Changing burner switch?
Brand: Whirlpool   Age: 1 - 5 years
how do I change a switch for the glass top large 8" burner??? I think I have my problem narrowed down to this and it would be a lot nicer to have control over my burner again.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-11-2008, 12:53 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide the most accurate advise I need the complete model number of the range.
Also I need to know the position of the bad burner (like the right front or the left rear or ...).
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-11-2008, 10:29 PM
Junior Member
Default
It's a Whirlpool model GR399LXG
  #4 (permalink)
Old 02-12-2008, 01:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The model number you posted is incomplete. There should be one more letter and a digit after"G".
__________________
  #5 (permalink)
Old 02-12-2008, 08:25 PM
Junior Member
Default
oops, let's try that again... it's Whirlpool Super Capacity 465 #GR399LXG. that's the model number posted in the Use and Care Guide
  #6 (permalink)
Old 02-12-2008, 08:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
They never published the complete model numbers in a book.
You can find the complete model number on the frame behind the bottom drawer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dual Burner switch on the blink again macmaxim Oven Repair (including Ranges and Cooktops) 4 07-17-2008 02:40 PM
Burner switch smokes rsdeacon Oven Repair (including Ranges and Cooktops) 1 02-06-2008 12:05 PM
Burner Switch Question dscarbrough Oven Repair (including Ranges and Cooktops) 1 01-31-2008 04:55 PM
infinite switch wiring change from 6 wires to 5 wire switch wiedemanndds Oven Repair (including Ranges and Cooktops) 3 12-06-2007 01:45 PM
Frigidaire - Changing Dual Surface Switch mrsdrjones Oven Repair (including Ranges and Cooktops) 6 11-09-2007 08:39 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
