I suspect the oven igniter is out, but want to ensure I've properly troubleshot to the right problem before I buy parts. Broiler & range works fine.
The igniter doesn't glow (at all) ... oven doesn't heat up ... a moment after turning on the oven the thermostat reading changes to "100" & stays there.
