DCS RGS-305 Stove top When I turn off the front, left burner, all the burners start to spark continuously. If I turn on the front, left burner the other burners will stop sparking once the front, left burner is lit. At that point, everything will work like it suppose to. Once I turn off the front, left burner again, all the burners start sparking continuously again. The only way to stop this continuous sparking if the front, left burner is turned off is to unplug the unit from the electric wall socket.
Thanks in advance.
Turned out to be a bad igniter switch on the front, left burner
