Discuss
Detached outer door panel on GE range
 in
The outer panel on my GE TrueTemp range door fell off. I acquired this range when I moved into the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Detached outer door panel on GE range
  #1 (permalink)
Old 08-28-2013, 06:40 AM
Junior Member
sharvan is on a distinguished road
Default Detached outer door panel on GE range
Brand: GE   Age: 5 - 10 years
The outer panel on my GE TrueTemp range door fell off. I acquired this range when I moved into the house three months ago and I do not know for sure its age/history. There is a strip of adhesive at the bottom of the main door apparently used to attach the outer panel. I am wondering about the feasibility and cost-effectiveness of repairing this and am debating the need for a new range. There is a strip of adhesive that is no longer sticky that apparently was used to attach the panel to the door, but I don't really see any hardware securing the door panel and that concerns me. There is also a lot of dried dripping between the glass panels in the door and near the handle/grill, the cleaning of which will require taking apart the door/removing the glass. Since there's no direct pathway for that dripping from the top edge of the door, I am wondering if the door has come apart previously. I am concerned about safety, seeing how readily this panel came off and how insecurely it was attached. Also, since that happened the door no longer stays open so it is not usable. Does it make sense to take apart the door, clean it, and install a new outer panel? Thanks.
File Type: jpg bottom of door underneath fallen outer panel.jpg (72.3 KB, 10 views)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replace glass panel on outer oven door danpatrick Oven Repair (including Ranges and Cooktops) 0 10-22-2011 01:03 PM
Outer door panel vlstenski7129@att.net Microwave Repair 0 02-10-2011 08:19 AM
Replace Microwave Outer Door Glass Panel ahovde Microwave Repair 0 11-01-2010 07:22 PM
replacing outer glass panel in five star range johnbl Oven Repair (including Ranges and Cooktops) 0 11-26-2009 07:13 AM
Remove outer door panel Davie Ninefingers Oven Repair (including Ranges and Cooktops) 2 11-28-2008 01:55 PM
