Discuss
Oven Lights Don't Work after Cleaning Cycle
 in
Hi, I have a double oven and ran the cleaning cycle on the top oven. The oven works fine but
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Lights Don't Work after Cleaning Cycle
  #1 (permalink)
Old 08-24-2013, 11:06 AM
Junior Member
wingfieldteam is on a distinguished road
Default Oven Lights Don't Work after Cleaning Cycle
Brand: Kitchen Aid   Age: 1 - 5 years
I have a double oven and ran the cleaning cycle on the top oven. The oven works fine but the lights no longer work in either oven. Both lights in the ovens are out. Tried changing the bulbs to no avail. Any suggestions? Thanks.
  #2 (permalink)
Old 08-24-2013, 12:01 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Never use the clean cycle on your ranges people always have problems afterwards because it's gets too hot and damages things. Check the voltage where the lights go into see if you have 120v. If you don't check the door switches for continuity. If the switches check out ok examine your wiring from where the light sockets and follow that path look for burns/cracks/damaged wire or connections. You gave no model number so i can't advise on you can break down the oven. More then likely just remove the back panel pieces and start tracking the wiring from both lighting circuits. Good luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid oven won't work after cleaning cycle geopharmer Oven Repair (including Ranges and Cooktops) 2 11-18-2012 07:13 AM
Oven won't work after the self cleaning cycle sluggermike Oven Repair (including Ranges and Cooktops) 5 11-29-2011 12:58 AM
GE Oven Cleaning Cycle Won't Work :-( ShoBizzzz Oven Repair (including Ranges and Cooktops) 0 11-08-2009 06:44 PM
Oven does not work after self-cleaning cycle Wufpak Oven Repair (including Ranges and Cooktops) 5 02-22-2009 08:21 PM
After Cleaning Cycle - Oven does not work bokeldol Oven Repair (including Ranges and Cooktops) 5 01-09-2008 06:59 PM
