Discuss
Upper element and broiler won't work
 in
I had a recent burnout of the upper oven heating element and have replaced the element. The lower oven works
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Upper element and broiler won't work
  #1 (permalink)
Old 08-24-2013, 07:09 AM
Junior Member
JC0123 is on a distinguished road
Default Upper element and broiler won't work
Model Number: Unknown   Brand: Jenn-Air   Age: More than 10 years
I had a recent burnout of the upper oven heating element and have replaced the element. The lower oven works properly. After replacing the upper oven element I noticed it will not come on but lower oven still worked properly. I swapped the lower and upper elements and noticed the lower oven still worked (with the new element) but no luck on the upper. Then I have noticed the upper broiler will not come on either. Normally a small light (above the control knob) will come on for the thermostat while heating, it will not come on for the upper oven. I have attached a photo of the control knobs on the oven. Thank you for any input.
Related Models
Maytag UNVIM98 MISC / ACCESSORY
Amana URC517MP COMMERCIAL MICROWAVES
Amana URCS511 COMMERCIAL MICROWAVES
Amana URCS511A COMMERCIAL MICROWAVES
Amana URFS511 COMMERCIAL MICROWAVES
Amana URFS518S COMMERCIAL MICROWAVES
Amana URS511 COMMERCIAL MICROWAVES
Amana URS511M COMMERCIAL MICROWAVES
Amana URS511MB COMMERCIAL MICROWAVES
Amana URS511P COMMERCIAL MICROWAVES
Menu Master US11EA COMMERCIAL MICROWAVES
Whirlpool UTX5536AAB0 (30")(36") Professional Hood
Maytag UXA1000AAB MISC / ACCESSORY
Maytag UXA1000AAP MISC / ACCESSORY
Maytag UXA1000AAQ MISC / ACCESSORY
Maytag UXA1000AAW MISC / ACCESSORY
Maytag UXA1027ADB MISC / ACCESSORY
Maytag UXA1027ADQ MISC / ACCESSORY
Maytag UXA1027ADW MISC / ACCESSORY
Maytag UXA1030ADB MISC / ACCESSORY
Maytag UXA1030ADQ MISC / ACCESSORY
Maytag UXA1030ADW MISC / ACCESSORY
Jenn-Air UXA9007AAB MISC / ACCESSORY
Jenn-Air UXA9007AAQ MISC / ACCESSORY
Jenn-Air UXA9007AAW MISC / ACCESSORY
Whirlpool UXG7360VDS0 36" OUTDOOR HOOD
Whirlpool UXG7480VDS0 48" OUTDOOR HOOD
Whirlpool UXL6036YSS0 36" & 48" PROFESSIONAL HOOD
Whirlpool UXL6048YSS0 36" & 48" PROFESSIONAL HOOD
Maytag UXT2030AAB HOOD
Maytag UXT2030AAQ HOOD
Maytag UXT2030AAS HOOD
Maytag UXT2030AAW HOOD
Whirlpool UXT2030AYB0 30" & 36" RANGE HOOD
Whirlpool UXT2030AYW0 30" & 36" RANGE HOOD
Maytag UXT2036AAB HOOD
Maytag UXT2036AAQ HOOD
Maytag UXT2036AAS HOOD
Maytag UXT2036AAW HOOD
Whirlpool UXT2036AYB0 30" & 36" RANGE HOOD
Whirlpool UXT2036AYW0 30" & 36" RANGE HOOD
Maytag UXT3030AAB HOOD
Maytag UXT3030AAQ HOOD
Maytag UXT3030AAS HOOD
Maytag UXT3030AAW HOOD
Whirlpool UXT3030AYB0 30" & 36" RANGE HOOD
Whirlpool UXT3030AYW0 30" & 36" RANGE HOOD
Maytag UXT3036AAB HOOD
Maytag UXT3036AAQ HOOD
Maytag UXT3036AAS HOOD
Maytag UXT3036AAW HOOD
Whirlpool UXT3036AYB0 30" & 36" RANGE HOOD
Whirlpool UXT3036AYW0 30" & 36" RANGE HOOD
Maytag UXT4030AAB HOOD
Maytag UXT4030AAQ HOOD
Maytag UXT4030AAS HOOD
Maytag UXT4030AAW HOOD
Whirlpool UXT4030AS0 30" & 36" RANGE HOOD
Whirlpool UXT4030AT0 30" & 36" RANGE HOOD
Whirlpool UXT4030AYB0 30" & 36" RANGE HOOD
Whirlpool UXT4030AYS0 RANGE HOOD
Whirlpool UXT4030AYT0 RANGE HOOD
Whirlpool UXT4030AYW0 30" & 36" RANGE HOOD
Maytag UXT4036AAB HOOD
Maytag UXT4036AAQ HOOD
Maytag UXT4036AAS HOOD
Maytag UXT4036AAW HOOD
Whirlpool UXT4036AS0 30" & 36" RANGE HOOD
Whirlpool UXT4036AT0 30" & 36" RANGE HOOD
Whirlpool UXT4036AYB0 30" & 36" RANGE HOOD
Whirlpool UXT4036AYW0 30" & 36" RANGE HOOD
Whirlpool UXT4230AAB0 30" & 36" RANGE HOOD
Whirlpool UXT4230AAQ0 30" & 36" RANGE HOOD
Whirlpool UXT4230AAS0 30" & 36" RANGE HOOD
Whirlpool UXT4230AAW0 30" & 36" RANGE HOOD
Whirlpool UXT4230AYB0 30" & 36" RANGE HOOD
Whirlpool UXT4230AYS0 30" & 36" RANGE HOOD
Whirlpool UXT4230AYT0 30" & 36" RANGE HOOD
Whirlpool UXT4230AYW0 30" & 36" RANGE HOOD
Whirlpool UXT4236AAB0 30" & 36" RANGE HOOD
Whirlpool UXT4236AAQ0 30" & 36" RANGE HOOD
Whirlpool UXT4236AAS0 30" & 36" RANGE HOOD
Whirlpool UXT4236AAW0 30" & 36" RANGE HOOD
Whirlpool UXT4236AYB0 30" & 36" RANGE HOOD
Whirlpool UXT4236AYS0 30" & 36" RANGE HOOD
Whirlpool UXT4236AYT0 30" & 36" RANGE HOOD
Whirlpool UXT4236AYW0 30" & 36" RANGE HOOD
Whirlpool UXT4830AAB0 30" & 36" RANGE HOOD
Whirlpool UXT4830AAS0 30" & 36" RANGE HOOD
Whirlpool UXT4830AAW0 30" & 36" RANGE HOOD
Whirlpool UXT4836AAB0 30" & 36" RANGE HOOD
Whirlpool UXT4836AAS0 30" & 36" RANGE HOOD
Whirlpool UXT4836AAW0 30" & 36" RANGE HOOD
Maytag UXT5230ADB HOOD
Maytag UXT5230ADQ HOOD
Maytag UXT5230ADS HOOD
Maytag UXT5230ADW HOOD
Whirlpool UXT5230AYB0 30" & 36" RANGE HOOD
Whirlpool UXT5230AYS0 30" & 36" RANGE HOOD
Whirlpool UXT5230AYW0 30" & 36" RANGE HOOD
Maytag UXT5236ADB HOOD
Maytag UXT5236ADQ HOOD
Maytag UXT5236ADS HOOD
Maytag UXT5236ADW HOOD
Whirlpool UXT5236AYB0 30" & 36" RANGE HOOD
Whirlpool UXT5236AYS0 30" & 36" RANGE HOOD
Whirlpool UXT5236AYW0 30" & 36" RANGE HOOD
Whirlpool UXT5330ADS0 30" & 36" RANGE HOOD (VENTED)
Whirlpool UXT5336ADS0 30" & 36" RANGE HOOD (VENTED)
Maytag UXT5430ADB HOOD
Maytag UXT5430ADQ HOOD
Maytag UXT5430ADS HOOD
Maytag UXT5430ADW HOOD
Maytag UXT5436ADB HOOD
  #2 (permalink)
Old 08-24-2013, 09:27 AM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
More then likely it's the upper oven thermostat switch and/or bake/broil selector switch.......i'd replace both for safe measure. Check your wiring at the upper thermostat switch and follow the wiring to the upper oven & broil you may have a loose connection or bad wiring. More then likely though it's your switches because it's both bake and broil. You didn't supply a model number so i can't tell you what the part number is. Call Jennair directly if you have a hard time finding the part. Good luck
  #3 (permalink)
Old 08-24-2013, 10:12 AM
Junior Member
Default
I believe it is Jenn Air model W-210, thanks for your help. The selector swith (in the photo) can be switch to "bake" and the lower oven temperature switch can be turned on and the burner works. No luck with the upper or broil under the same scenario. Thank you again for your response.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven/broiler not lighting upper burners work gotsweetpea Oven Repair (including Ranges and Cooktops) 0 01-05-2012 03:26 PM
Oven element and broiler element won't work mikusm Oven Repair (including Ranges and Cooktops) 0 10-10-2010 09:48 PM
Broiler Upper Oven Element Replacement Auzzie Oven Repair (including Ranges and Cooktops) 3 10-04-2010 02:31 PM
Oven upper (broil) element does not work DanT Oven Repair (including Ranges and Cooktops) 1 12-02-2008 01:09 PM
Broiler element won't work kelrey Oven Repair (including Ranges and Cooktops) 0 07-02-2008 02:54 PM
