The broiler element stopped working on my GE oven and when I checked the continuity with an ohm meter the element tested OK. I had noticed sporadic F1 messages coming up previously but these went away after a reset by turning the power on and back on. It appears that the oven control board may be at fault so I am prepared to replace it however when I compare the wiring of the current board with the new board there appear to be differences specifically on the connections to the two relays for the oven and broil elements. Before I purchase the new board I would like to have confirmation that these connection issues can be resolved. Can anyone help. I have attached photos of the current board as currently installed. Thanks for your help.
