RCHelm
#1 Posted : Friday, August 23, 2013 10:00:50 AM(UTC)
RCHelm
The largest burner will not ignite. I have checked to insure that it is clean. There does not seem to be gas supply to this burner. Will not light with match. Igniter is sparking well.
HumboldtRepairMan
#2 Posted : Friday, August 23, 2013 5:54:40 PM(UTC)
HumboldtRepairMan
Sounds like you may have a problem with that individual burner valve if all the other burners work good and it ignites good at that burner just no gas being released....Here's a parts page #314 is the part you most likely need. Make sure if you replace it to do a test to make sure you did it right and it has no leaks........use a can of windex or bubbly water after you turn the gas valve at the wall back on after the repair. Good luck
Control Panel parts for GE J2S968SEK3SS - AppliancePartsPros.com
