Discuss
Gas oven heats then shuts off..help
 in
Hello- I have a Roper gas oven that will heat up to desired temperature then shut off. It will not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas oven heats then shuts off..help
  #1 (permalink)
Old 08-23-2013, 11:17 AM
Junior Member
alohamomma is on a distinguished road
Default Gas oven heats then shuts off..help
Brand: Roper   Age: More than 10 years
Hello-
I have a Roper gas oven that will heat up to desired temperature then shut off. It will not go back on until the oven cools off, usually somewhere in the 200 degree range. It does not matter what the set temperature is, 300-500, it will always reach the set temp then it shuts off. ANy idea what this could be? Thank you!
  #2 (permalink)
Old 08-23-2013, 06:57 PM
Junior Member
randylewis is on a distinguished road
Default
Quote:
Originally Posted by alohamomma View Post
Hello-
Do you have a model # ?
  #3 (permalink)
Old 08-23-2013, 10:03 PM
Junior Member
Default
Yes...model #B8758b2. Thank you!
  #4 (permalink)
Old 09-08-2013, 02:29 PM
Junior Member
Default
bump (thank you!)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven control shuts down like it over heats notsobright Oven Repair (including Ranges and Cooktops) 1 01-21-2013 07:08 PM
gas range oven heats up but then shuts off Dash Oven Repair (including Ranges and Cooktops) 3 08-26-2009 09:01 PM
dryer heats up and shuts off mike rundquist Dryer Repair 2 11-10-2008 05:13 PM
heats for 10 mins..shuts off phillip melton Dryer Repair 0 07-29-2008 01:10 PM
dryer heats up then shuts off that_guy Dryer Repair 2 05-27-2008 11:01 AM
