Discuss
Oven Door Whirlpool SF305PEEN O
 in
My wife removed the oven door to clean the oven now we cannot get the door back on, help.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Door Whirlpool SF305PEEN O
  #1 (permalink)
Old 08-21-2013, 08:27 AM
Junior Member
jeremey is on a distinguished road
Question Oven Door Whirlpool SF305PEEN O
Brand: Whirlpool   Age: 5 - 10 years
  #2 (permalink)
Old 08-21-2013, 10:04 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is the operators manual it has info on the door removal and install.
http://www.whirlpool.com/digitalasse...%203196286.pdf
__________________
  #3 (permalink)
Old 08-21-2013, 05:24 PM
Junior Member
Post Still cannot get the door on
This must be an older door as the manual was not the same as what she has. One manual we found said to put the "pins" in under the hinge. We do not have the pins, I've tried bolts/screws etc.
When putting the door up to the oven at a 45 degree angle, something catches and as you pull the door downwards, the hinge does not move but all of a sudden it retracts back into the door.
Is there some way to put something under the higes to keep them out?
Thanks for your help.
  #4 (permalink)
Old 08-22-2013, 04:26 AM
Senior Expert
APP Volunteer
Default
Sorry but I do not understand the above. Without being there I cannot be of much help.
That is what the pins or bolts or whatever you sue is supposed to do.
Here are the parts for this unit
Parts for Whirlpool SF305PEEN0 Range - AppliancePartsPros.com
If you click on the description or picture of the hinges item 8 in the Door Parts section you will get a better view . They do seem to match the ones in the manual I sent.
The hinge plate has to be pulled down and then the pins put in place to hold it out away from the door.
Then push the door into the receivers in the unit. The door may have to be held at a bit of an angle to do this.
Then wiggle it so it drops some. This is to get the slots in the hinge to fit onto the pins in the receiver. You could have another person do this (wiggle and pulling downward while you hold the door.
This is to get the two pins in the receiver into the slots in the hinge plate.
So the door/hinge has to go in and then down.
Once the hinge is connected to the receiver pins you can lower it slightly and remove the pins you used to lock the hinge plate.
FYI: I am calling the part of the hinge mechanism that is inside the oven wall the receiver.
If all else fails try getting someone else to do this. Some folks are just lucky at getting things like this together.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Oven Door DJrFam Oven Repair (including Ranges and Cooktops) 3 03-21-2011 03:54 AM
Whirlpool Oven Door KARENSUCHY Oven Repair (including Ranges and Cooktops) 0 01-25-2011 02:49 PM
Whirlpool Oven Door whirlpool 77 Trash Compactor Repair 0 10-28-2010 09:05 AM
Whirlpool Oven Door Tim K Oven Repair (including Ranges and Cooktops) 0 06-14-2008 07:14 AM
Whirlpool oven door too hot danmari5 Oven Repair (including Ranges and Cooktops) 1 01-30-2008 04:15 AM
