kcjonz
#1 Posted : Monday, August 19, 2013 12:49:06 PM(UTC)
kcjonz
Whirlpool oven turns on and preheats normally, then sometime during baking the elements stop heating. Lights and control board function normally and the heat light is lit indicating an element is on. Upon cycling power neither element will heat. Checked the breaker and it is not tripped. I cycled the breaker several times and then finally both elements work again.
I thought it was a fluke and then 2 days later the same thing.
I am uncertain if flipping the breaker is causing the oven to come back on or if it is due to the oven having time to cool down that allows it to work again.
My thoughts are either
1)One leg of the breaker is going bad and getting flaky under load.
2)Temperature safety switch in the oven going bad
Any thought would be appreciated.
HumboldtRepairMan
#2 Posted : Monday, August 19, 2013 3:56:43 PM(UTC)
HumboldtRepairMan
Can't help without a model number
kcjonz
#3 Posted : Tuesday, August 20, 2013 6:16:45 AM(UTC)
kcjonz
Gbs307prb01
whirlpool range GS395LEG (Oven Repair (including Ranges and Cooktops))
by Guest Yesterday at 12:17:23 PM(UTC)
Whirlpool WRF757SDEM01 led light problem (Refrigerator & Freezer Repair)
by Guest 3/16/2024 1:02:12 PM(UTC)
Whirlpool WRS325SDHB08 Icemaker works intermittently (Refrigerator & Freezer Repair)
by donl1150 3/2/2024 5:04:55 AM(UTC)
Whirlpool Quiet Partner II Repair (Dishwasher Repair)
by Scubacrazy56 3/1/2024 7:54:50 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Whirlpool Gold GD5SHA Freezer Temperature Rises Overnight (Refrigerator & Freezer Repair)
by jrb98391 2/22/2024 10:20:17 AM(UTC)
Whirlpool wtw4815ew1 Black Residue/Marks and Shaking Violently (Washer Repair)
by crvtec 2/14/2024 5:05:43 PM(UTC)
Whirlpool Cabrio WTW6300SW1 (Washer Repair)
by Fieldsafo 2/12/2024 4:00:47 PM(UTC)
Whirlpool french door w/ bottom freezer (Refrigerator & Freezer Repair)
by JumperWire 2/11/2024 1:41:25 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool Oven WFE770H0FZ2 (Oven Repair (including Ranges and Cooktops))
by Guest 2/9/2024 7:03:09 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool heat pump dryers (Dryer Repair)
by Aptmtncguy 1/19/2024 3:44:50 PM(UTC)
Whirlpool Gs6SHAXML00 (Refrigerator & Freezer Repair)
by shelbast20 1/17/2024 5:58:47 AM(UTC)
whirlpool wfg510s0ab2 oven not lighting (Oven Repair (including Ranges and Cooktops))
by sparktender 1/15/2024 1:43:04 PM(UTC)
