Discuss
Haunted Amana gas range
 in
Oven was unable to get over 300 degrees no matter what it was set at. I replaced the temperature probe.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Haunted Amana gas range
  #1 (permalink)
Old 10-09-2009, 10:37 AM
917gene 917gene is offline
Junior Member
917gene is on a distinguished road
Default Haunted Amana gas range
Model Number: ARG7102   Brand: Amana   Age: 5 - 10 years
Oven was unable to get over 300 degrees no matter what it was set at. I replaced the temperature probe. Same problem.
I replaced the electric control unit (Eaton KRC - Gas) and got an F3 code. So, for a laugh, I reattached the old control unit and now it too gives me an F3 code too ! As stated earlier, the old control unit worked and gave no F3 code.
I've disconnected the power. I've checked all the probe wiring and connectors for continuity. No problems detected.
I've heard enough beeping to last a lifetime. What do you suggest ?
Thank you
Related Models
Amana ARG7102C Range - S/c S/i Ddraft Gas
Amana ARG7102L Range - S/c S/i Ddraft Gas
Amana ARG7102W Range - S/c S/i Ddraft Gas
Amana ARG7200L Range - S/c S/i Ddraft Gas
Amana ARG7200W Range - S/c S/i Ddraft Gas
Amana ARG7202 E Range - S/c S/i Ddraft Gas
Amana ARG7300LL Range - S/c S/i Ddraft Gas
Amana ARG7300W Range - S/c S/i Ddraft Gas
Amana ARG7300WW Range - S/c S/i Ddraft Gas
Amana ARG7301L Range - S/c S/i Ddraft Gas
Amana ARG7301LL Range - S/c S/i Ddraft Gas
Amana ARG7301W Range - S/c S/i Ddraft Gas
Amana ARG7301WW Range - S/c S/i Ddraft Gas
Amana ARG7302CC Range - S/c S/i Ddraft Gas
Amana ARG7302LL Range - S/c S/i Ddraft Gas
Amana ARG7302WW Range - S/c S/i Ddraft Gas
Amana ARG7303CC Range - S/c F/s Gas
Amana ARG7303LL Range - S/c F/s Gas
Amana ARG7303WW Range - S/c F/s Gas
Amana ARG7600CC Range - S/c S/i Ddraft Gas
Amana ARG7600L Range - S/c F/s Gas
Amana ARG7600LL Range - S/c S/i Ddraft Gas
Amana ARG7600W Range - S/c S/i Ddraft Gas
Amana ARG7600WW Range - S/c S/i Ddraft Gas
Amana ARG7800CC Range - S/c S/i Ddraft Gas
Amana ARG7800E Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 10-15-2009, 03:50 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Answered here: Amana ARG-7102 F3 and stuff
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
amana range allenbonthuis Oven Repair (including Ranges and Cooktops) 0 10-09-2009 06:30 AM
Haunted Dryer? slimjim Dryer Repair 8 05-29-2009 09:53 AM
amana range kkwah Oven Repair (including Ranges and Cooktops) 0 03-03-2009 09:34 AM
amana range slag Oven Repair (including Ranges and Cooktops) 5 01-29-2009 07:10 AM
amana range slag Oven Repair (including Ranges and Cooktops) 0 01-24-2009 03:26 PM
