Discuss
Jenn-air oven not heating
 in
My Jenn-air oven suddenly stopped heating. No error codes. Display shows preheat and 100 degrees. Same problem whether Bake, Convect
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-air oven not heating
  #1 (permalink)
Old 08-18-2013, 09:34 AM
Junior Member
windrider354 is on a distinguished road
Default Jenn-air oven not heating
Model Number: W27400   Brand: Jenn-Air   Age: More than 10 years
My Jenn-air oven suddenly stopped heating. No error codes. Display shows preheat and 100 degrees. Same problem whether Bake, Convect Bake or Broil.
Neither top or bottom element gets hot, but I can hear periodic clicking like a switch is trying to call for heat.
Appreciate advice, especially if it sounds like a single part I can replace.
Thanks very much.
Related Models
Jenn-Air W27400B WALLOVEN- S/C ELE
Jenn-Air W27400W WALLOVEN- S/C ELE
Jenn-Air W2750B WALLOVEN- S/C ELE
Jenn-Air W2750B-C WALLOVEN- S/C ELE
Jenn-Air W2750W WALLOVEN- S/C ELE
Jenn-Air W2750W-C WALLOVEN- S/C ELE
Jenn-Air W276 WALLOVEN- S/C MWAVE ELE
Jenn-Air W276W WALLOVEN- S/C MWAVE ELE
Jenn-Air W2780B WALLOVEN- S/C ELE
Jenn-Air W2780B-C WALLOVEN- S/C ELE
Jenn-Air W2780W WALLOVEN- S/C ELE
Jenn-Air W2780W-C WALLOVEN- S/C ELE
Whirlpool W2RXEMMWB00 REFRIGERATOR
Whirlpool W2RXEMMWB01 REFRIGERATOR
Whirlpool W2RXEMMWQ00 REFRIGERATOR
Whirlpool W2RXEMMWQ01 REFRIGERATOR
Whirlpool W2RXEMMWS00 REFRIGERATOR
Whirlpool W2RXEMMWS01 REFRIGERATOR
Whirlpool W2RXNMMWB00 REFRIGERATOR
Whirlpool W2RXNMMWB01 REFRIGERATOR
Whirlpool W2RXNMMWB02 REFRIGERATOR
Whirlpool W2RXNMMWL00 REFRIGERATOR
Whirlpool W2RXNMMWL01 REFRIGERATOR
Whirlpool W2RXNMMWL02 REFRIGERATOR
Whirlpool W2RXNMMWQ00 REFRIGERATOR
Whirlpool W2RXNMMWQ01 REFRIGERATOR
Whirlpool W2RXNMMWQ02 REFRIGERATOR
Jenn-Air W30100B WALLOVEN- S/C ELE
Jenn-Air W30100BC WALLOVEN- S/C ELE
Jenn-Air W30100W WALLOVEN- S/C ELE
Jenn-Air W30100WC WALLOVEN- S/C ELE
Jenn-Air W30400B WALLOVEN- S/C ELE
Jenn-Air W30400BC WALLOVEN- S/C ELE
Jenn-Air W30400P WALLOVEN- S/C ELE
Jenn-Air W30400PC WALLOVEN- S/C ELE
Jenn-Air W30400PF WALLOVEN- S/C ELE
Jenn-Air W30400PG WALLOVEN- S/C ELE
Jenn-Air W30400PK WALLOVEN- S/C ELE
Jenn-Air W30400PR WALLOVEN- S/C ELE
Jenn-Air W30400PU WALLOVEN- S/C ELE
Jenn-Air W30400PV ELECTRIC WALL OVEN
Jenn-Air W30400W WALLOVEN- S/C ELE
Jenn-Air W30400WC WALLOVEN- S/C ELE
Whirlpool W3CG3014XB00 30" GAS COOKTOP
Whirlpool W3CG3014XS00 30" GAS COOKTOP
Whirlpool W3CG3014XW00 30" GAS COOKTOP
Whirlpool W4TXNGFWQ00 REFRIGERATOR
Whirlpool W4TXNGFWQ01 REFRIGERATOR
Whirlpool W4TXNGFWQ02 REFRIGERATOR
Whirlpool W4TXNWFWB01 REFRIGERATOR
Whirlpool W4TXNWFWQ00 REFRIGERATOR
Whirlpool W4TXNWFWQ01 REFRIGERATOR
Whirlpool W4TXNWFWQ02 REFRIGERATOR
Whirlpool W4TXNWFWT00 REFRIGERATOR
Whirlpool W4TXNWFWT01 REFRIGERATOR
Whirlpool W4TXNWFWT02 REFRIGERATOR
Whirlpool W5CE3024XB00 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool W5CE3024XS00 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool W5CE3024XW00 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool W5CG3024XB00 30" GAS COOKTOP
Whirlpool W5CG3024XS00 30" GAS COOKTOP
Whirlpool W5CG3024XT00 30" GAS COOKTOP
Whirlpool W5CG3024XW00 30" GAS COOKTOP
Whirlpool W5CG3625XB00 30" GAS COOKTOP
Whirlpool W5CG3625XS00 30" GAS COOKTOP
Whirlpool W5CG3625XW00 30" GAS COOKTOP
Whirlpool W5TXDWFXQ00 REFRIGERATOR
Whirlpool W5TXEWFWB00 REFRIGERATOR
Whirlpool W5TXEWFWQ00 REFRIGERATOR
Whirlpool W5TXEWFWT00 REFRIGERATOR
Whirlpool W5TYDWFXQ00 REFRIGERATOR
Whirlpool W5WCE055XW0 AIR CONDITIONER
Whirlpool W5WCE065XW0 AIR CONDITIONER
Whirlpool W5WCE085XW0 AIR CONDITIONER
Whirlpool W5WCE105XW0 AIR CONDITIONER
Whirlpool W5WCE128XW0 AIR CONDITIONER
Whirlpool W6RXNGFWB00 REFRIGERATOR
Whirlpool W6RXNGFWB01 REFRIGERATOR
Whirlpool W6RXNGFWQ00 REFRIGERATOR
Whirlpool W6RXNGFWQ01 REFRIGERATOR
Whirlpool W6RXNGFWS00 REFRIGERATOR
Whirlpool W6RXNGFWS01 REFRIGERATOR
Whirlpool W6TXNWFWQ00 REFRIGERATOR
Whirlpool W6TXNWFWQ01 REFRIGERATOR
Whirlpool W6TXNWFWQ02 REFRIGERATOR
Whirlpool W6TXNWFWT00 REFRIGERATOR
Whirlpool W6TXNWFWT01 REFRIGERATOR
Whirlpool W6TXNWFWT02 REFRIGERATOR
Whirlpool W7WCC065XB0 AIR CONDITIONER
Whirlpool W7WCC085XB0 AIR CONDITIONER
Whirlpool W7WCC105XB0 AIR CONDITIONER
Whirlpool W7WCC128XB0 AIR CONDITIONER
Whirlpool W8CRNGMXD00 REFRIGERATOR
Whirlpool W8CRNGMXQ00 REFRIGERATOR
Whirlpool W8FLNGFVD00 REFRIGERATOR
Whirlpool W8FLNGFVQ00 REFRIGERATOR
Whirlpool W8FRNGFVD00 REFRIGERATOR
Whirlpool W8FRNGFVD01 REFRIGERATOR
Whirlpool W8FRNGFVQ00 REFRIGERATOR
Whirlpool W8FRNGFVQ01 REFRIGERATOR
Whirlpool W8FXNGMWD00 REFRIGERATOR
Whirlpool W8FXNGMWQ00 REFRIGERATOR
Whirlpool W8RXCGFXB00 REFRIGERATOR
Whirlpool W8RXCGFXB01 REFRIGERATOR
Whirlpool W8RXCGFXQ00 REFRIGERATOR
Whirlpool W8RXCGFXQ01 REFRIGERATOR
Whirlpool W8RXCGFXS00 REFRIGERATOR
Whirlpool W8RXCGFXS01 REFRIGERATOR
Whirlpool W8RXDGFXB00 REFRIGERATOR
Whirlpool W8RXDGFXB01 REFRIGERATOR
Whirlpool W8RXDGFXQ00 REFRIGERATOR
Whirlpool W8RXDGFXQ01 REFRIGERATOR
Whirlpool W8RXDGFXS00 REFRIGERATOR
Whirlpool W8RXDGFXS01 REFRIGERATOR
Whirlpool W8RXEGFWB00 REFRIGERATOR
Whirlpool W8RXEGFWQ00 REFRIGERATOR
Whirlpool W8RXEGFWS00 REFRIGERATOR
Whirlpool W8RXEGMVB00 REFRIGERATOR
Whirlpool W8RXEGMVQ00 REFRIGERATOR
Whirlpool W8RXEGMVS00 REFRIGERATOR
  #2 (permalink)
Old 08-18-2013, 09:53 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I cannot find any tech info on this unit.
Parts for W27400 - AppliancePartsPros.com
But the first thing I would check is the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
The heating elements require the full 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If the power is good and since the unit stays in pre-heat then odds are high that the control board/timer is toast.
I would check the wiring just in case you have a burned off connector or some other wiring problem.
I cannot find a fuse or thermal cut-off in the parts that would stop power to the elements.
__________________
  #3 (permalink)
Old 08-18-2013, 12:06 PM
Junior Member
Default
Power to oven is OK. Now when I first try to heat oven after power up, I get a F5 code. Only the first time.
  #4 (permalink)
Old 08-18-2013, 01:30 PM
Senior Expert
APP Volunteer
Default
Here is what comers up for that error code.
I cannot confirm that it applies to your unit as I cannot find a tech sheet on it.
F5---Hardware and watchdog circuits disagree---Replace clock assembly (also called the ERC)
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air Oven not heating and light comes on by itself tdjohnson740 Oven Repair (including Ranges and Cooktops) 5 04-10-2012 04:21 PM
Non heating Top Oven Electric Jenn-Air gogto Oven Repair (including Ranges and Cooktops) 0 06-20-2011 08:33 PM
Jenn Air Wall Oven - Not Heating jreadhead Oven Repair (including Ranges and Cooktops) 0 11-19-2009 11:17 AM
