Discuss
Fridgidair oven will not come on
 in
My Frigidaire gas oven will not come on. Broiler works. The glow coil is coming on but it appears the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Fridgidair oven will not come on
  #1 (permalink)
Old 08-18-2013, 09:17 AM
Junior Member
dbell1967 is on a distinguished road
Default Fridgidair oven will not come on
Model Number: FGFL67DBB   Brand: Frigidaire   Age: 5 - 10 years
My Frigidaire gas oven will not come on. Broiler works. The glow coil is coming on but it appears the gas valve is not turning on. I replaced the dual gas valve and it came right on and heated to temp set. My wife tried turning it on the next day and it did not come on after leaving it on for an hour. Just the glow coil was working. everything else works on the appliance. What other component would control the gas valve? I can find no part on the diagram that shows a temp sensor. Is the control panel the only other replacement option?
Related Models
Frigidaire FGFL67DBB Frigidaire/range
Frigidaire FGFL67DBD Frigidaire/range
Frigidaire FGFL67DBF Frigidaire/range
Frigidaire FGFL67DBG Frigidaire/range
Frigidaire FGFL67DBH Frigidaire/range
Frigidaire FGFL67DBJ Frigidaire/gas Range
Frigidaire FGFL67DBK GAS RANGE
Frigidaire FGFL67DBL GAS RANGE
Frigidaire FGFL67DCA Frigidaire/gas Range
Frigidaire FGFL67DCB Frigidaire/gas Range
Frigidaire FGFL67DCC Frigidaire/gas Range
Frigidaire FGFL67DCD Frigidaire/range
Frigidaire FGFL67DCE Frigidaire/range
Frigidaire FGFL67DCF Frigidaire/range
Frigidaire FGFL67DCG Frigidaire/range
Frigidaire FGFL67DCH Frigidaire/gas Range
Frigidaire FGFL67DCJ Frigidaire/range
Frigidaire FGFL67DCK Backguard
Frigidaire FGFL67DCL GAS RANGE
Frigidaire FGFL67DCM GAS RANGE
Frigidaire FGFL67DCN GAS RANGE
Frigidaire FGFL67DQA Frigidaire/gas Range
Frigidaire FGFL67DQB Frigidaire/range
Frigidaire FGFL67DQD Frigidaire/range
Frigidaire FGFL67DQF Frigidaire/range
Frigidaire FGFL67DQG Frigidaire/range
Frigidaire FGFL67DSA Frigidaire/gas Range
Frigidaire FGFL67DSB Frigidaire/range
Frigidaire FGFL67DSD Frigidaire/range
Frigidaire FGFL67DSF Frigidaire/range
Frigidaire FGFL67DSG Frigidaire/range
Frigidaire FGFL67DSH Frigidaire/range
Frigidaire FGFL67DSJ Frigidaire/gas Range
Frigidaire FGFL67DSK GAS RANGE
Frigidaire FGFL67DSL GAS RANGE
Frigidaire FGFL67HBA GAS RANGE
Frigidaire FGFL67HBB GAS RANGE
Frigidaire FGFL67HBC GAS RANGE
Frigidaire FGFL67HBD GAS RANGE
Frigidaire FGFL67HBE GAS RANGE
Frigidaire FGFL67HBF GAS RANGE
Frigidaire FGFL67HBG GAS RANGE
Frigidaire FGFL67HBH GAS RANGE
Frigidaire FGFL67HBJ GAS RANGE
Frigidaire FGFL67HCA GAS RANGE
Frigidaire FGFL67HCB GAS RANGE
Frigidaire FGFL67HCC GAS RANGE
Frigidaire FGFL67HCD GAS RANGE
Frigidaire FGFL67HCE GAS RANGE
Frigidaire FGFL67HCF GAS RANGE
Frigidaire FGFL67HSA GAS RANGE
Frigidaire FGFL67HSB GAS RANGE
Frigidaire FGFL67HSC GAS RANGE
Frigidaire FGFL67HSD GAS RANGE
Frigidaire FGFL67HSE GAS RANGE
Frigidaire FGFL67HSF GAS RANGE
Frigidaire FGFL67HSG GAS RANGE
Frigidaire FGFL67HSH GAS RANGE
Frigidaire FGFL67HSJ GAS RANGE
Frigidaire FGFL77ABB Frigidaire/range
Frigidaire FGFL77ABC Frigidaire/range
Frigidaire FGFL77ABD Frigidaire/gas Range
Frigidaire FGFL77ABE Frigidaire/gas Range
Frigidaire FGFL77ABF Frigidaire/gas Range
Frigidaire FGFL77ABH Frigidaire/gas Range
Frigidaire FGFL77ABJ Frigidaire/gas Range
Frigidaire FGFL77AQB Frigidaire/range
Frigidaire FGFL77AQC Frigidaire/range
Frigidaire FGFL77AQD Frigidaire/gas Range
Frigidaire FGFL77AQE Frigidaire/gas Range
Frigidaire FGFL77AQF Frigidaire/gas Range
Frigidaire FGFL77AQH Frigidaire/gas Range
Frigidaire FGFL77AQJ Frigidaire/gas Range
Frigidaire FGFL77ASB Frigidaire/range
Frigidaire FGFL77ASC Frigidaire/range
Frigidaire FGFL77ASD Frigidaire/gas Range
Frigidaire FGFL77ASE Frigidaire/gas Range
Frigidaire FGFL77ASF Frigidaire/gas Range
Frigidaire FGFL77ASH Frigidaire/gas Range
Frigidaire FGFL77ASJ Frigidaire/gas Range
Frigidaire FGFL79DBA Frigidaire/gas Range
Frigidaire FGFL79DBB Frigidaire/range
Frigidaire FGFL79DBC Frigidaire/range
Frigidaire FGFL79DBE Frigidaire/range
Frigidaire FGFL79DBF Frigidaire/range
Frigidaire FGFL79DBG Frigidaire/range
Frigidaire FGFL79DBH Frigidaire/range
Frigidaire FGFL79DCA Frigidaire/gas Range
Frigidaire FGFL79DCB Frigidaire/gas Range
Frigidaire FGFL79DCC Frigidaire/range
Frigidaire FGFL79DCD Frigidaire/range
Frigidaire FGFL79DQA Frigidaire/gas Range
Frigidaire FGFL79DQB Frigidaire/range
Frigidaire FGFL79DQC Frigidaire/range
Frigidaire FGFL79DQE Frigidaire/range
Frigidaire FGFL79DQF Frigidaire/range
Frigidaire FGFL79DQG Frigidaire/range
Frigidaire FGFL79DQH Frigidaire/range
Frigidaire FGFL79DSA Frigidaire/gas Range
Frigidaire FGFL79DSB Frigidaire/range
Frigidaire FGFL79DSC Frigidaire/range
Frigidaire FGFL79DSE Frigidaire/range
Frigidaire FGFL79DSF Frigidaire/range
Frigidaire FGFL79DSG Frigidaire/range
Frigidaire FGFL79DSH Frigidaire/range
Frigidaire FGFL79ECA Frigidaire/gas Range
Frigidaire FGFL79ECB Frigidaire/gas Range
Frigidaire FGFL79ECD Frigidaire/range
Frigidaire FGFL79FCA Frigidaire/gas Range
Frigidaire FGFL79FCB Frigidaire/range
Frigidaire FGFL79FCC Frigidaire/range
Frigidaire FGFL79GBA GAS RANGE
Frigidaire FGFL79GBB GAS RANGE
Frigidaire FGFL79GBC GAS RANGE
Frigidaire FGFL79GBD GAS RANGE
Frigidaire FGFL79GBE GAS RANGE
Frigidaire FGFL79GBF GAS RANGE
Frigidaire FGFL79GCA GAS RANGE
Frigidaire FGFL79GCB GAS RANGE
Frigidaire FGFL79GCC GAS RANGE
  #2 (permalink)
Old 08-18-2013, 04:41 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
If you have 120v going to the bake ignitor and it doesn't open the safety valve the ignitor is weak or going bad probably. Take a multimeter with an amp clamp and see if your pulling 3 amps or more if you are the ignitor should be fine. Also if you don't have an amp clamp visually inspect the ignitor to see if it's ashy or white if so it needs replacement.
Here's your parts
Burner parts for Frigidaire FGFL67DBB - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fridgidair microwave pops tarheelcraftsman Microwave Repair 0 05-07-2012 09:40 AM
GE frontloader washer by Fridgidair craigpage Washer Repair 13 03-31-2012 03:35 PM
Fridgidair Replacement Part HopelessRepairman Oven Repair (including Ranges and Cooktops) 0 03-23-2010 08:45 AM
Fridgidair ice maker srichie Refrigerator & Freezer Repair 0 07-16-2009 02:34 PM
Fridgidair dishwasher won't work megandunlap Dishwasher Repair 0 01-02-2009 12:31 PM
