cslvburns
#1 Posted : Thursday, August 15, 2013 11:58:05 AM(UTC)
cslvburns
My gas oven ignitor isn't working, the broiler one works fine. I can get to the ignitor and detach it but I can't get to the connectors. The white wires go back behind the oven wall and I can't see where they connect with the power. Any suggestions. This is a slide-in model and I am new to this.
Thank you.
HumboldtRepairMan
#2 Posted : Thursday, August 15, 2013 3:41:44 PM(UTC)
HumboldtRepairMan
Don't need to get to the connector just buy the new ignitor it comes with ceramic twist nuts so you can cut the wire and twist nut them in.......Make sure when you cut the wires they don't fall back into the hole and go inside the cavity otherwise you have to pull it out and remove the back panel to get to them.....
Good luck
gas oven ignitor cost (Oven Repair (including Ranges and Cooktops))
by Guest 10/30/2021 5:43:49 AM(UTC)
Thermador gas oven ignitor does not spark (Oven Repair (including Ranges and Cooktops))
by indiana 3/2/2012 5:25:51 PM(UTC)
GE Profile gas oven Ignitor Connections question (Oven Repair (including Ranges and Cooktops))
by meltmtl 1/2/2011 5:29:45 PM(UTC)
GE Gas Oven ignitor not glowing (Oven Repair (including Ranges and Cooktops))
by needhelp63 1/18/2010 6:46:49 AM(UTC)
gas oven ignitor burns up immediately when installed (Oven Repair (including Ranges and Cooktops))
by caldwellczech 10/12/2009 11:07:05 AM(UTC)
Gas oven ignitor glows, gas flows, no flame (Oven Repair (including Ranges and Cooktops))
by bubba8cake 7/9/2009 3:49:36 PM(UTC)
gas oven ignitor (Oven Repair (including Ranges and Cooktops))
by jleitz 12/5/2008 3:05:17 PM(UTC)
