burners work, oven door locked and display does not work.:(
Here are your parts Parts for KESS908 - AppliancePartsPros.comChoose the correct unit from Matching Model Numbers side panel. See the attachment for a tech sheet. Your given model number is short a few digits but it looks like most units in this series are the same. The below is for a PB02. Looks like the power transformer and some components have a thermal cutoff and a thermal switch in the L1 side of the line so I would start by checking them. Both should be 0 ohms at room temperature. If either is open it is a good idea to also check the oven sensor just to be sure that it did not cause an overheating condition. |
THIS FORUM IS DEAD!!!!!!! |
