PCGreg
#1 Posted : Monday, August 5, 2013 7:01:55 PM(UTC)
PCGreg
This past week we were getting ready to use the oven and turned it on to pre-heat. When we went to put the food in the upper oven the door was locked as if it was cleaning. The temp was set to about 400 and I saw the upper heating element on. I immediately turned power off to the oven at the breaker panel. Today I turned power back on and the door unlocked but the upper heating element came on even though the upper oven was not turned on. Yikes! What part(s) do I replace?
#2 Posted : Wednesday, August 7, 2013 1:32:37 AM(UTC)
Parts for Whirlpool GBD307PDB7 Wall Oven - AppliancePartsPros.com
Sounds like the control board (item 3 in the Control Panel Parts section) is toast re: either the broil relay contacts are welded together or the electronics that control the relay are bad.
Unfortunately it looks like it is obsolete but I would call them just to be sure.
You may be able to locate a replacement if you search around.
If not there are companies out there that repair old boards, just Google "appliance timer repair"
PCGreg
#3 Posted : Wednesday, August 7, 2013 7:14:20 AM(UTC)
PCGreg
Unfortunately, just as I suspected. Any idea where that relay is located on the board, i.e. where I should be looking? Assuming I find a bad relay, any idea where I might locate another one? Fortunately for me I have access to some pretty nice equipment and some experts at circuit card assemblies.
Last and certainly not least, thanks much for your reply. I really appreciate it!
#4 Posted : Wednesday, August 7, 2013 9:26:00 AM(UTC)
It should help you trace the circuit back to find the relay.
Schematics of the electronics on the board are not published by the manufacturers.
I think Digi-Key sells them but odds are that there are other vendors if you can get the manufacturers number off the relay.
File Attachment(s):
GBD307.pdf (326kb) downloaded 8 time(s).
Whirlpool Oven Upper Heating Element won't turn off (Oven Repair (including Ranges and Cooktops))
by ilfang 1/18/2009 1:46:19 PM(UTC)
